Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: Toshiba PCB, HELP ME!
PostPosted: April 7th, 2011, 10:15
I guys, i must buy this HDD PCB:
Toshiba 250GB SATA MK2555GSX, HDD2H24 E UL01 T
I found it here on ebay
http://cgi.ebay.com/Toshiba-250GB-SATA- ... 0495961742
but it costs 40$!!!!!!
IMPORTANT: If you look on the other images there's a code:
IF39YG8Y0 What's this?
Cuz i've exactly the same model but this code on my HDD is different....... thanks :(
 Post subject: Re: Toshiba PCB, HELP ME!
PostPosted: April 7th, 2011, 15:52
Someone can help me?
PostPosted: April 7th, 2011, 15:54
Whats wrong with your PCB?
PostPosted: April 7th, 2011, 15:57
"Fear has big eyes"
What is the original problem with your drive? How is it feel?
Angel Data Recovery
PostPosted: April 7th, 2011, 16:30
Even if you did purchase that PCB from EBay how did you plan on programming it?
PostPosted: April 8th, 2011, 7:41
I must change PCB cuz i've made touch directly the PCB of my 2,5 HDD to the floor, once time i gone to spin it, it shows me:
Impossible to find the OS. So, i scorched the HDD! :mrgreen:
But i have to know this point:
IF39YG8Y0 What's this? It's really important this code?
Thanks.
PostPosted: April 10th, 2011, 11:20
Guys, i uploaded 2 images of my HDD:
http://img52.imageshack.us/i/1000779.jpg/
http://img855.imageshack.us/i/1000781.jpg/
On the HDD's label there isn't written the Part Numeber, so, maybe that number is the P/N?
P.S. I remember that i have this code different form that one on Ebay.
PostPosted: April 10th, 2011, 13:44
a "simple" PCB swap will not work on these HDD's.
The key to solving your problem is diagnosing the fault correctly.
I'm struggling to understand your post, but did the drive fall and hit the floor?
Data Recovery Ireland
PostPosted: April 10th, 2011, 14:22
To me sounds like he dropped the HDD on the floor and he touched the PCB I am not sure with what but seens he feels he shorted it out when he touched it. Also looks like he has attached it again and not able to find his OS. So now he feels it is spinning up once he needs a new PCB for it. That is what I get out of this one.
Iorana Haraharaini
PostPosted: April 11th, 2011, 7:50
No guys and sorry for the misunderstanding.
I supported the hdd to the floor, then i have connected the hdd through an adapter SATA/USB to my pc but evidently the contact of the PCB directly with the floor has scorched the HDD.
I hope to have been more clear. If not yet, please, say me it.
Why?
However guys you don't answer to my question: That numeber is the P/N right? Cuz i can't understand if is the P/N or another code...... i uploaded the images and liked the ebay links above. Please, see em.
Thanks.
PostPosted: April 11th, 2011, 7:53
Toshiba drives contain "adaptive" data that is unique to each drive, so the PCB cannot simply be changed. It requires further modification.
Also, your photos are not good enough quality. It would be helpful if you removed the PCB and uploaded a photo of the component side.
PostPosted: April 11th, 2011, 9:37
as CK said, Toshiba drives have unique information to each of their drives on their boards. So a simple board swap will not work.
PostPosted: April 11th, 2011, 9:56
ok, i'll upload photos with PCB removed.
But yet i have not answer to my question: what's that number? That code????
So? Also if i find an IDENTIC PBC, it won't work? :shock:
PostPosted: April 11th, 2011, 10:23
Correct.
PostPosted: April 11th, 2011, 17:54
Guys, but is so hard to answer to this question, this is the 4th times but nobody answer to this question.......
Correct.
So...... how i can do?
in what sense? Equal PCB, also if they're pratically equal in all, contain differents "data"? And what's this "data"?
Say me ALL. I have too important dates on my HDD and i MUST recover em.
Thanks.
PostPosted: April 11th, 2011, 18:15
Do you have PC3000 UDMA or so ?
PostPosted: April 11th, 2011, 18:25
The code you are referring to is effectively irrelevant to recovering your data so please stop asking.
The PCB's are not equal, that is the problem. They contain unique data, specific to each drive, embedded in the PCB.
If your data is valuable, you really should seek professional assistance. However, if you are unhappy about spending $40, then perhaps your data is not valuable. A professional service will be a lot more.
As I said initially, you need to diagnose the fault correctly before you start swapping PCB's, etc. There are some users here who may help you to diagnose a blown fuse, etc.
To summarise, do not waste your money on a PCB as swapping it will not fix your problem. You need to diagnose the fault correctly. It may be a a fuse or it may be worse. If it's worse, you may need to swap the controller, which is usally a BGA chip on Toshiba HDD's and this is definitely NOT a DIY job.
PostPosted: April 11th, 2011, 19:29
You will need to transfer IC602 from your original board to your donor PCB.
See this similar thread:
http://www.deadharddrive.com/forums/vie ... hp?p=10451
Your local TV/AV repair shop should be able to perform the transfer.
However, before spending any money, check the fuse near the SATA power connector.
PostPosted: April 12th, 2011, 1:01
@seabroke,
Ask IF THEY HAVE PRO BGA REWORK EQUIPMENT and then if yes HOW MUCH WILL THEY CHARGE. You'll wonder at the results... :mrgreen:
This just because Italy is not China regarding labour cost and taxes.
Or invest some time of your life finding ways to do without.
In any of the case above it's big bucks at play.
PostPosted: April 12th, 2011, 1:38
BlackST wrote:
@seabroke,
IC602 is a DIP, not BGA. A simple SMT rework station, or even a temperature controlled soldering iron, will do the job. I'm aware of people who have had similar jobs done for US$20.
Users browsing this forum: No registered users and 203 guests
