Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba PCB, HELP ME!
PostPosted: April 12th, 2011, 3:40
Toshiba are not Seagate...
PostPosted: April 12th, 2011, 3:43
Hi all,
in Italy you can find plenty of DR professionals not only me or BlackST, you have a big choice.
If you want to try the DIY remember also what CK told you about diffculties and then decide what you you want to do; i don't like to help in DIY because i get bored working on drives after the end user tried to recover and made DR impossible making me waste my time.
So if data is not so important you can make all the experiments but if content worth to pay a professional think about.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: April 12th, 2011, 14:13
The code you are referring to is effectively irrelevant to recovering your data
Finally! :D
if you are unhappy about spending $40, then perhaps your data is not valuable
Ok, i want spend 40 euro or more, what i have to buy?
You will need to transfer IC602 from your original board to your donor PCB.
Thanks but now you say me i can buy another identic PCB and make the transfer, others say me that is useless buy another PCB cuz toshiba has unique data in each drive....... So? :shock:
A simple SMT rework station
What's this SMT?
PostPosted: April 12th, 2011, 19:00
To get your data, you need:
1) Replacement PCB
2) Transfer MCU to new board
The MCU is a BGA chip and requires specialised equipment to remove and replace.
What we were saying previously was that a simple PCB swap would not work, hence the advice not to buy it.
SMT/SMD = Surface Mount Components
Data Recovery Ireland
PostPosted: April 13th, 2011, 1:52
...assuming the mcu is still working.
PostPosted: April 13th, 2011, 8:02
IC602 is a DIP, not BGA. A simple SMT rework station, or even a temperature controlled soldering iron, will do the job.
So this is a wrong? Is a DIP or BGA?
But for to do this, i must buy a new identic PCB, right? And transfer this MCU to the old board to new one, right?
@ BlackST, sarebbe un vero piacere se mi rispondessi ai PM, se c'è qualche problema o semplicemente non vuoi per qualche tuo motivo, dimmelo, io sono qui :wink:
PostPosted: April 13th, 2011, 9:21
You HAVE pm :)
PostPosted: April 16th, 2011, 4:39
See this thread:
http://www.deadharddrive.com/forums/vie ... hp?p=10451
... and this one:
how-can-fix-shorted-toshiba-mk326gsx-t19060.html
The OP did not need to transfer the MCU, only IC602. Take the PCB to your TV repair shop.
PostPosted: April 16th, 2011, 8:37
In Italy ? How much do you think they charge TAXES PAID if you find one willing to do it ? (seems that almost only ASCs survived... ) Surprise... 8)
PostPosted: July 18th, 2011, 11:26
Ok guys, finally i've disassembled the HDD.
Here you are the images:
There's nothing scorched, so, whaere's the problem?? :roll:
What component i must change?
Thanks.
PostPosted: July 24th, 2011, 9:36
PLEASE, someone help me! :(
PostPosted: July 26th, 2011, 18:05
here you go the missing images:
PostPosted: July 31st, 2011, 13:03
Please, someone can say the component "IC602" where is located? :cry:
PostPosted: August 1st, 2011, 6:59
It should be written on the board, next to the chip.
PostPosted: August 1st, 2011, 7:29
Look here:
PostPosted: August 4th, 2011, 22:28
on the temperature note, what temp or wattage do you recommend for Transferring the IC602 Chip?
PostPosted: August 6th, 2011, 5:16
WTF! :evil: Thank you so much!
Now, for the transfer i must do this:
1) Replacement PCB
2) Transfer MCU (IC602) to new board
I can buy another PCB quietly on ebay, but the component "IC602" is equal on all Toshiba PCB ALWAY belonging to the same model?
Thanks.
PostPosted: August 24th, 2011, 9:10
WTF! Thank you so much!
1) Replacement PCB
Thanks.
......... :cry:
and then.....
What's the answer?
Users browsing this forum: Google [Bot] and 178 guests
