Forum rules
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Mini USB to SATA (DATA) Diagram
PostPosted: April 10th, 2011, 13:01
Dear guys,
Anyone knows the Pinout to Convert the Mini USB to SATA (Data Only) output???
fzabkar, i guess maybe you are the one for this my dear :wink:
 Post subject: Re: Mini USB to SATA (DATA) Diagram
PostPosted: April 11th, 2011, 19:36
Sorry, I don't understand your question. Can you be more specific?
PostPosted: April 12th, 2011, 16:24
Hi man, thnx for the reply
Here is it:
I wanted to convert from this Interface (Mini USB)
http://1.bp.blogspot.com/_0YXWT72vucI/S ... pinout.png
to SATA Data
http://www.sierra-cables.com/Cables/Ima ... able-1.jpg
have you ever tried this?
PostPosted: April 12th, 2011, 16:48
Not possible. USB and SATA are different.
PostPosted: April 12th, 2011, 17:03
well, i guess my friend that everything is possible Its the matter of time only
remember that there is a converter from SATA 2 USB
what makes you think or decide vise verse is not possible?
convince me on this !!!
thnx
PostPosted: April 12th, 2011, 18:23
Sure, you can have a converter, but as the protocols are not the same at all it will involve more than just a "pinout"
PostPosted: April 13th, 2011, 4:04
Well, drc, i hope you`re wrong on this,,, but i will continue my research,,,
thnx
PostPosted: April 13th, 2011, 17:11
There is a bridge IC in between .
PostPosted: April 15th, 2011, 16:14
How many do you want?
http://www.google.pt/images?hl=pt-PT&bi ... a=N&tab=wi
PostPosted: April 16th, 2011, 5:03
RicardoNC wrote:
AIUI, the OP wants to connect a SATA controller (host) to a USB peripheral, not the other way around. I'm not aware of any bridges that can do this.
PostPosted: April 16th, 2011, 5:56
ur right on this
i was googling alot but never found such a thing about it
i dono why is it difficult to go one way and the reverse is not possible for this case?
PostPosted: April 16th, 2011, 6:41
einstein9 wrote:
ur right on this
Reverse should be possible, otherwise how it would be!
http://www.salvationdata.com/data-recov ... dapter.htm
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: April 17th, 2011, 9:55
shahij, have u ever tried it? or got it working?
that is the question here :wink:
PostPosted: April 17th, 2011, 10:23
No, I didn't try it. It should work, otherwise why will they tell it, also they did quote it $260.
My question also - Is there any member who has been using it and working as stated?
__________
THANK YOU
SHAHI
PostPosted: April 17th, 2011, 12:35
well maybe probably someone did it, we never know.
but the link you provided is way far from the one am looking for.
am still doing some testing here, love the research of the 0-Day :wink:
PostPosted: April 17th, 2011, 14:08
mr. shahij , it will not work .
Salvation data "Mr. Edison" said
" For the USB to IDE adapter, it is firstly used to connect the USB drives with its USB port, and then you can use one cable IDE to connect with other data equipment.
So far according to our test, it works with USB devices to perform data backup and data clean using DCK, it doesn't work to perform firmware operations. It can be connected with DC to recover lost data due to accidental deletion, format and other logical recovery cases. It is not as good as connecting directly to IDE drives if with bad sectors, but it worked."
:D
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 17th, 2011, 14:39
:D
Thanks for your information.
Well, in this case, how to access the SA for further analysis?
example of a drive - WD5000BMVV
http://www.hdd-donor.com/pics/1290113551.jpg
http://img.auctiva.com/imgdata/2/9/2/0/ ... 773_tp.jpg
http://www.qudong.com/uploads/userup/09 ... 15W543.jpg
__________
THANK YOU
SHAHI
PostPosted: April 17th, 2011, 15:23
Pay Attention to the Initio Chip
you can convert this to SATA to access the SA but NO DATA will be accessed
coz of the chip.
you will see this in WD,Samsung 2.5"
PostPosted: April 21st, 2011, 16:15
thnx
Drc is right. It has no sense.
It's like ferrari for trailer.
Explain why you need that ?
Angel Data Recovery
PostPosted: April 22nd, 2011, 12:56
DR-Kiev wrote:
thnx
again doing some research here on this matter :idea:
