Forum rules
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Mini USB to SATA (DATA) Diagram
PostPosted: April 22nd, 2011, 18:45
I find these drives quite frustrating. Forcing us to read a drive via the USB interface is like imaging a drive with Data Compass instead of DDI...slow, awkward and with limited control over success. The guy who came up with the idea of having the integrated USB interface should be flogged.
Recovery Force Data Recovery
PostPosted: April 23rd, 2011, 2:41
Agree
PostPosted: April 29th, 2011, 4:54
Hi, I also require a dedicated usb to ide or sata adapter to work/experiment on an encrypted drive. The Salvationdata device would probably do the job but I would like to ask if anybody knows of an adapter which dosn't cost $260.
PostPosted: April 30th, 2011, 18:24
I have a solution from Salvation Data that is free to connect the new Western Digital USB drives. I asked for a better solution but it should work for now.
How to connect WD USB interface HDD to HD Doctor.pdf [539.32 KiB]
Downloaded 1174 times
PostPosted: May 1st, 2011, 6:01
by doing so, you are bypassing something = no data access
plus this solution is not from Salvation, from one Russian Team they did it.
meanwhile i noticed that there are more people are not participating on this topic but they are either know another way and for sure they know why am looking for it.
thnx for the reply man and ur time :>
PostPosted: May 1st, 2011, 20:30
I agree. That solution, to the best of my knowledge, will only give access to the SA.
PostPosted: May 2nd, 2011, 11:20
gosh! in this life...there's too much to learn :(
PostPosted: May 2nd, 2011, 12:36
You can't adapt USB to SATA with a "pinout" any more than you can adapt either to firewire with a "pinout". The protocol is different and the physical connection is different and will require some bridge chip to convert
PostPosted: May 2nd, 2011, 12:49
that is the home work research am working on
thnx :> :wink:
PostPosted: May 2nd, 2011, 15:50
I'm tired to talking about that encrypted data (read via SATA) could be easily decrypted with external USB board (base on same inic1607E or symwave). Just need to know few important rules.
:!: Few proper experiments will give results.
Angel Data Recovery
PostPosted: May 3rd, 2011, 5:51
I know what you mean here by :idea:
and i managed to solve the WD in some cases, the reason am asking is Value Added to the tests am doing.
its just like the MAC Slogan: Think Different
and that is what am doing now, sure there are many ways/routes to Destination, i know the long way, and trying to explore the Shorter ways in my spare time (research).
Thnx for the Advice :wink:
PostPosted: May 9th, 2011, 7:20
I see on ebay.co.uk theirs a USB 3.0 to SATA cable
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
PostPosted: May 9th, 2011, 15:54
If you look closely, it is for a SATA drive to be connected to a computer via USB. The post is looking for an adapter to connect USB drives to a SATA port.
