 Post subject: Seagate ST2000dl003
PostPosted: April 20th, 2011, 17:32
Helllo
my Drive was not found anymore on my computer!
I read much bout firmware problems.
I build some parts to contact the drive,
Here is the output of putty:
Rst 0x40M
RW: Disc Ctlr Initialization Completed.
MC Internal LPC Process
(P) SATA Reset
User Data Base 00991AE8
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011985C 4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00004548
[RSRS] 09EF
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
00001BA4 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
Can anyone help me ?
What commands i had to type?
 Post subject: Re: Seagate ST2000dl003
PostPosted: April 21st, 2011, 6:54
What exactly happened before and AFTER the drive didn't come up on PC anymore ? (I don't believe in ghosts...) :mrgreen:
PostPosted: May 1st, 2011, 2:21
A systemmessage comes up mbr..... or if more then 2gb or so i canceld the nessage!
And after that the hdd cant find in bios or system.
PostPosted: May 9th, 2011, 5:27
i've the same problem with this seagate 2TB-HDD and the same terminallog.
Did anyone find a solution for this problem or can give a hint?
Thanks in advance.
Jeffo
PostPosted: May 9th, 2011, 6:47
Chris2804 wrote:
Helllo
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 09EF
00001BA4 00000000
[MCMTWS]
Power it Up again, and listen carefully does it spin normal or some small heads movement issue?
listen carefully to the sound.
Advice, if you dono just get a working one same model and compare the sound in both you should notice the diff.
good luck
PostPosted: May 9th, 2011, 14:26
It Spins normal!
PostPosted: May 10th, 2011, 11:51
I have seen this problem just once, but client needed same day service and I had no time to find solution.
I can tell you that is 100% not a simple / DIY fix.
You need professional assistance for any hope of saving your data. Any attempts at the repair / recovery will very likely cause further complications and incur additional work in a professional lab.
PostPosted: May 12th, 2011, 10:24
correct, more DIY result in more damage
Users browsing this forum: No registered users and 232 guests
