 Post subject: WD5000AAKB Should I exchange Plates?
PostPosted: June 6th, 2011, 9:30
Hello there a first time here !
Well this is my sad history... my WD5000AAKB fell, I've opened up and accidentally bend the sensible heads, and now the only solution that comes to mind its to exchange plates with a donor HD.
Leave you're advice.
Thanks !
 Post subject: Re: WD5000AAKB Should I exchange Plates?
PostPosted: June 6th, 2011, 9:43
If the platters are spinning normally, why would you swap the platters to another drive?
PostPosted: June 6th, 2011, 9:48
Because I've opened up, and accidentally damaged the heads :cry:
PostPosted: June 6th, 2011, 10:04
look, if you want to do repair yourself, which I do not recommend, then address only what got damaged and not other components!
PostPosted: June 6th, 2011, 10:08
Well, that was my intention just check it out what was going on inside, but accidentally the heads bend I'm not and expert but for sure the damage its worst :(
PostPosted: June 6th, 2011, 10:10
Stop now, send the drive to a pro before it is too late.
PostPosted: June 6th, 2011, 10:13
Ok, can someone give a list of where to send it ? and an estimate of how much it will cost ?
PostPosted: June 6th, 2011, 10:21
For us, most of the time, these drives are recovered for $1250 or less. Now that the drive has been opened and damaged internally, it is hard to say for sure what the cost will be.
As to where to send it, it really depends on where you are located.
Users browsing this forum: Google [Bot] and 73 guests
