 Post subject: HTS541080G9AT00
PostPosted: June 20th, 2011, 4:41
Hi
I have this HD that doesn't spin up with is PCB. I have tried a similar one, and it spins OK, so I need to change PCB.
What do I need to check for compatibility? Number of the PCB only? Then, just swap the U6 chip, or anything else?? Send PM :mrgreen:
ACELab partner
 Post subject: Re: HTS541080G9AT00
PostPosted: June 20th, 2011, 6:40
Check fuse F1 first, if not...
Match 1st two lines of PCB and swap NVRAM chip.
PostPosted: June 20th, 2011, 7:00
Hi Pcimage
Fuse is OK unfortunately :mrgreen:
Gonna find a PCB.
Thanks for your help.
:wink: :wink:
ACELab partner
PostPosted: June 20th, 2011, 7:54
Gives you a good opportunity to use your new heat gun from Eric Lee ;)
Data Recovery Cape Town
PostPosted: June 20th, 2011, 11:49
somebody say to use fluxant when de-soldering with hot air, i always made it without ( i do not have to clean the pins afterwards )
PostPosted: June 20th, 2011, 12:36
FLUX also prevents messing points BTW
IT IS A MUST for any Pro. electronics workshop
Users browsing this forum: No registered users and 281 guests
