 Post subject: WD Passport ?'s
PostPosted: July 18th, 2011, 15:29
I know these drives can be a pain to work with so before I get into it, I'm going to tell you what I have and have not done.
My customer brought it to me and said she needs her quickbooks off it and some other misc stuff off it.
I plugged it in and could see the directory structure but from what I recall, these drives encrypt all your data.
psychically the drive is fine, I just need to get the data off.
I'm thinking if I plug install the software on my tower it will back up my hd right over her data. So the question is how do I get her data off the drive w/o the original computer?
Dave
 Post subject: Re: WD Passport ?'s
PostPosted: July 18th, 2011, 16:01
Not sure if it will let you read it (if it's encrypted), but connecting through a Write Blocker will prevent writing anything to the drive (avoiding an over-write). I use one made by Tableau. It is expensive though unless you need one frequently.
PostPosted: July 18th, 2011, 16:30
The customer told me there is no password, but it still appears to be encrypted looking at it from windows. I can see it becoming encrypted if they used the software to back it up but I believe the encryption is done from a chip in the enclosure, which I have and is working properly. Basically you can't take the HD out and read it w/o the enclosure. (correct me if I'm wrong).
Any ideas or what other info do you need from me regarding this project?
PostPosted: July 18th, 2011, 16:59
So what is preventing you from copying the drive and/or data?
PostPosted: July 19th, 2011, 11:47
What makes you think this?
The encryption will encrypt everything including partition information, boot sectors and data. Effectively if the data was encrypted you would not see the folders/files or even the partition.
You are offering a data recovery service with even the slightest idea of how this HDD works?? :o
If you can see the data, simply recover it. Simple. :D
Users browsing this forum: No registered users and 252 guests
