 Post subject: Seagate FreeAgent Go 9KW2AH-502 500GB Facing serious problem
PostPosted: September 28th, 2011, 11:58
I am having some serious problem with my external hard disk two month ago some virus attacked my hard disk and damaged some of data.
After happening this my hard disk was not working well. I wasn't able to copy my data. Mostly my data was damaged after that i had formated it with normal quick format method provided by windows 7.
Now problem is it is still not working good. Small data works good but when i start copying bunch of data together lets say about 10 GB. It works very slow and some time could not even copy so anyone can solve my problem please help me.
My hard disk details:- Seagate FreeAgent Go 9KW2AH-502 500GB
 Post subject: Re: Seagate FreeAgent Go 9KW2AH-502 500GB Facing serious pro
PostPosted: September 28th, 2011, 12:01
If you have formatted it then data obviously is of no importance so my advice is to RMA it if still in warranty, or else simply replace it.
If you have this much problems then realistically it is not reliable storage for any data.
PostPosted: September 28th, 2011, 12:03
Can you tell me what is RMA??
PostPosted: September 28th, 2011, 12:09
http://www.seagate.com/www/en-us/suppor ... assistance
PostPosted: September 28th, 2011, 12:13
Ohk i get it i had tried to do tests with SeaTools when i was facing problems before formatting the HDD and all tests wasn't able to complete and fails to test tha HDD now i am going to do these tests again but what if i don't get any SeaTools test code??
PostPosted: September 28th, 2011, 12:14
when you are copying this 10GB, how many files are we talking? Just because it's 10GB of data doesn't mean it can't take a while if the file count is high, especially if you are copying using windows it has to crc check each file as it copies, which is why you will get really increased transfer times if the file count is high, even if the data amount is the same.
PostPosted: September 28th, 2011, 12:17
5 movies = 10 GB
PostPosted: September 29th, 2011, 1:04
Highly doubt you are dealing with a virus situation. More than likely, the external is failing. My guess is bad sectors.
Pretty sure you will not want to spend a couple hundred dollars for some movies, right?
RMA-ing the drive and downloading the movies again is probably the easiest thing to do.
PostPosted: September 29th, 2011, 2:38
That shouldn't be a problem. Just use any error code or N/A, I have done this in the past without problems.
PostPosted: September 29th, 2011, 2:58
Agree with these guys, just RMA it and make it Seagates problem!
PostPosted: September 29th, 2011, 8:53
Thank you very much every one i got the test code and i am going for RMA.
Again Thank you very much
Users browsing this forum: No registered users and 254 guests
