 Post subject: Help please
PostPosted: October 19th, 2011, 21:19
Hi All, Iam a new member with a Bizzare situation and ineed your expert advice. I have 10 yr old son and external HD(Iomega) 1tb.
Until last sunday i had approx 500gb of stuff, diff softwares, training .iso files & black ops game files. i connected my extHD to XBox to cpy black Ops onto Xbox. Bad time, door bell rang had to attend. In da meantime my son deleted all the files, all is gone just in a 30 secs. Can you please please help me recover my files, they are my life, career. will be greatful to you guys, Regards :(
 Post subject: Re: Help please
PostPosted: October 19th, 2011, 21:50
Try "Nucleus Kernel for FAT and NTFS" or "GetDataBack"
Good luck
PostPosted: October 19th, 2011, 22:19
try running recuva on the drive to scan for deleted data
PostPosted: October 20th, 2011, 4:21
If your son just deleted the files and didn't write anything on it, chances are high that you'll be able to recover the files. You may try to use R-Undelete. The article So, what do you have to do to get deleted files back? explains how. With one difference - as this is an external disk, you can install R-Undelete on your system disk. Also worth noting is that R-Undelete gives you the "try before buy" approach, so you can estimate chances for successful file recovery for free.
R-Studio Data Recovery Software
PostPosted: October 20th, 2011, 4:39
Hi, are you sure the files were deleted by your son as it is also possible for the drive/caddy to develop a fault?
You could try any of the above though I would suggest to run Dmde on the drive. Download it to and run from your desktop. In the menu select the drive and scan for a partition. Then post back with your results.
Users browsing this forum: Bing [Bot] and 88 guests
