 Post subject: No Power Seagate Goflex Overvoltage
PostPosted: November 4th, 2011, 13:20
I accidentally plugged in my laptop's adapter to my seagate external desk storage which has 19v. The original adapter is only 12 v=2A. The item is still under warranty but I'm afraid they will just pull out the item and replace it with new one. I even tried to plugged it in my computer using sata cable but my pc doesn't detect it anymore. I have lots of files there it's almost 1tb of important files. Please help me!
PN: 9ZQ2N1-500 1 TB
SN: NA0JYKXD
 Post subject: Re: No Power Seagate Goflex Overvoltage
PostPosted: November 4th, 2011, 13:30
send it to Pro. and those seagate are really tricky if ur data are valuable
do not try any DIY
PostPosted: November 4th, 2011, 19:02
The usual result is a shorted 12V TVS diode, in which case there is a simple, zero-cost DIY fix. There is nothing tricky about it, except maybe in finding a way to get inside the enclosure.
See http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
If you need help in locating the diode, please upload a detailed photo of the USB-SATA bridge board inside the enclosure. We would also need to see the component side of the board on the HDD.
PostPosted: November 4th, 2011, 19:16
opening the enclosure is not difficult too
http://youtu.be/K_nnGhUIo8E
PostPosted: November 4th, 2011, 19:18
it's not difficult to open the enclosure
PostPosted: November 4th, 2011, 19:29
Good. Let's see some photos. :-)
PostPosted: November 4th, 2011, 20:05
is there a chance that it will work on its previous state like nothing happened with intact data?
PostPosted: November 4th, 2011, 21:34
I've seen this same problem in many different storage forums.
Lots of success stories ...
http://www.google.com/search?q=%22tvs+d ... +supply%22
PostPosted: November 5th, 2011, 0:26
would it cost me much like what data recovery services are offering? where I can get replacement for tvs diodes buy a new one with the same model?
PostPosted: November 5th, 2011, 2:39
Your TVS diode questions are answered in my FAQ article.
Questions regarding cost will no doubt be answered via PM. However, a replacement board plus firmware transfer should cost around US$50, if your board supplier does it for you.
PostPosted: November 5th, 2011, 23:20
should I open now and void my warranty? do you think seagate will not know it? does varying hdd model matters when replacing diodes or do I need exact same model? should I wear gloves before opening it?
PostPosted: November 7th, 2011, 6:27
I got it working 2 ic has been replaced
Users browsing this forum: No registered users and 159 guests
