 Post subject: ST9250315AS-visible in BIOS but cannot be visible in OS
PostPosted: February 19th, 2011, 14:09
Hi, problem like described in subject.
HDD visible in BIOS but cannot be visible in OS (Win XP)
I tried to checki it in VICTORIA and HDTune255 and I can find disk but only 8GB!
VICTORIA message
Get drive passport: Drive error!
Get SMART command... Error reading SMART!
http://obrazki.elektroda.pl/9562826600_1298067463.html
http://obrazki.elektroda.pl/4438545900_1298067646.html
Checked on two PC and same results. I only want to collect data from it.
Next I tried MHDD:
MHDD>eid
[PRE]
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY AMNF T0NF ABRT IDNF UNCR BBK 04
[ST9250315AS ] [ 0] [ ] [ ]
SN:5VC8KA1H FW:0010 CACHE:8192KB
Supports: LBA48 HPA DLMC LBA MS16 DMA (UDMA5,MWDMA2)
SMART: Enabled SelfTest: Supported ErrorLog: Supported
Security: high, OFF. Size = 0MB
IMPORTANT NOTICE: This device does not
support LBA mode. MHDD will NOT work with this device.
MHDD>rhpa
ST9250315AS LBA:0 BIOS: 81H
SN:5VC8KA1H FW:0010 CACHE:8192KB Size = 0MB
Init drive: [RECAL]
RECAL FAIL
Read NHPA command...
Fail.
Done (RHPA).
Any way to force LBA mode ?
 Post subject: Re: ST9250315AS-visible in BIOS but cannot be visible in OS
PostPosted: November 25th, 2011, 16:17
hai risolto con il messaggio di errore get drive passport error in victoria???
come???
PostPosted: November 25th, 2011, 16:25
You likely have a firmware issue, but a professional diagnostic is best if data is of the outmost importance.
PostPosted: November 25th, 2011, 16:34
I would like to continue ...
but you have tested victoria pass to unlock hard drive?
PostPosted: November 27th, 2011, 9:22
what firmware??
PostPosted: November 27th, 2011, 11:10
sanlima wrote:
what firmware??
You can always use the search button, it's there for purpose :wink:
Seagate and 0Mb is a well discussed topic.
Bosse
http://www.rescue-it.se
PostPosted: November 27th, 2011, 16:03
sanlima wrote:
what firmware??
This is firmware in reference to the "programming code" if you will that operates the drive.
Users browsing this forum: Google [Bot] and 292 guests
