 Post subject: Barracudas base compatibility
PostPosted: November 30th, 2011, 3:56
Hi all,
I want to replace base of a 7200.11 1.5TB (ST31500341AS) with seized motor. The only similar base I have available is from a 7200.11 1000GB (ST31000333AS).
Can someone confirm these two bases are compatible?
 Post subject: Re: Barracudas base compatibility
PostPosted: November 30th, 2011, 11:31
The spindle bearings will probably be the same. So if you are looking to change the seized bearing then all should be OK (but a micrometer will tell for sure). Personally I only ever swap the bearing, I prefer to keep the platters on the original hub both for platter alignment and balance.
I have found that many Seagate drives use common spindle motor bearings.
Hope this helps..
Steve..
East Anglian Data Recovery Services
http://www.eadr.co.uk
"If it's your only copy - then it's not a backup!"
PostPosted: November 30th, 2011, 14:13
Thanks Steve.
I just tried it and it works just fine. All went well. I'm imaging drive as we speak. It's imaging slowly but I get loads of green sectors :D
Thanks again.
Dimitris
PostPosted: December 1st, 2011, 11:17
If you don't mind, what tool did you use?
PostPosted: December 1st, 2011, 11:52
PM' ed
PostPosted: December 1st, 2011, 17:08
Thank you
PostPosted: December 2nd, 2011, 4:43
No problem ;-)
Users browsing this forum: No registered users and 224 guests
