 Post subject: Question about pcb needed?
PostPosted: December 24th, 2011, 12:55
I have a WD pcb that is burnt out. On the actual PCB it is printed with 2060-701335-005 REV A, However the white sticker says 2061-701335-D00 AD and then some other stuff underlined.
If i was to look for a pcb to replace mine, which code should i be searching for? I also understand i need to change my u12 chip from the old pcb to the new one.
 Post subject: Re: Question about pcb needed?
PostPosted: December 24th, 2011, 13:12
Also, I have another similar hard drive that has a similar pcb.
2060-701335-003 rev b is printed on the board
2061-701335-000 AG is on the white sticker.
would this be good enough pcb to switch the u12s??
PostPosted: December 24th, 2011, 17:18
Hi.
Yes it should do.
PostPosted: December 25th, 2011, 3:06
No it wont because your drive is Hawk and the donor drive is Sabre58 these pcbs looks same but they are no interchangeable .
PostPosted: December 25th, 2011, 6:27
It has worked for me in the past just fine.
PostPosted: December 26th, 2011, 5:12
you have to care about 701335 only xxxxx-701335-xxx in all Wd pcb except 701640 . care about 701640-002 or whatever
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: December 27th, 2011, 16:19
Ok lets see if it works or not .
Users browsing this forum: No registered users and 403 guests
