 Post subject: ST2000DM00​1 2TB/64MB 7200 Not Detected On SATA2 Port
PostPosted: December 28th, 2011, 21:46
Hi All,
A few days ago, I purchased a brand new Seagate ST2000DM001 2TB/64MB 7200 (SN: S24*****) to be used as a data storage disk.
My problem is that this HDD is detected by BIOS when I plug it into a SATA 3 port but it is not detected by BIOS when I plug it into a SATA 2 port. This appears very strange to me as I know SATA 3 HDDs are backward compatible and my other SATA 3 HDDs worked fine when plugged into SATA 2 or SATA 3 ports.
My system configuration are:
- MB: ASUS P7H55-M/USB3
- BIOS: Version 1105 (latest)
- Marvel Controller: 1045 (latest)
- OS: Windows 7 Home
My troubleshooting so far are:
- Re-formatted it several times when plugged into SATA 3 port but BIOS still cannot detect this HDD when it is plugged into SATA 2 port. This is tedious as each format takes 5-6 hours!
- Check for latest firmware from Seagate but there isn't any yet.
- I don't have a spare PC to check this HDD at the moment.
Could this be due to its 2TB capacity that my MB cannot detect on SATA 2 port? I want to make sure it is not a hardware problem as it is only a few days old.
Any help appreciated, thanks so much!
 Post subject: Re: ST2000DM00​1 2TB/64MB 7200 Not Detected On SATA2 Port
PostPosted: December 28th, 2011, 21:52
Is the SATA 2 port enabled in BIOS?
PostPosted: December 28th, 2011, 22:02
Hi there,
Yes, all my six SATA 2 ports are fine and working as I checked all of them previously using a good HDD.
PostPosted: December 28th, 2011, 22:29
How is the good HDD different than the one that is not working?
PostPosted: December 28th, 2011, 22:32
Hi labtech,
My good HDDs are WDC 500GB and WDC 1TB. My problem HDD is Seagate Barricuda 2TB.
PostPosted: December 29th, 2011, 9:46
What is the exact procedure you're using to format the drive? 6 hours is a very long time, even if you are using low level format tools, and that maybe indicates some h/w problem with the drive. Did you check SMART?
PostPosted: December 29th, 2011, 10:39
hi northwind,
i totally agree that my format period was too long. i used W7's disk management to perform full format.
how do i check my SMART?
thanks!
PostPosted: December 29th, 2011, 12:02
I think there is no reason to use full format for this case. Anyway, if you want to check SMART there are many freeware products that can do this for you, just google it. One is HDTune.
PostPosted: December 29th, 2011, 12:40
actually a full format of a 2tb drive in windows 7 could take that longs since it is wiping every sector of the drive. But a quick format is all that is needed.
PostPosted: December 29th, 2011, 13:11
Brittlestars wrote:
hi northwind,
thanks!
It is a great software that you can use to check to see if it is bad. People said it is 95% accurate. You can google it and install it in your computer. Then follow the instruction on the screen. There are short and long tests you can use.
PostPosted: December 29th, 2011, 13:15
Brittlestars wrote:
Hi labtech,
After checking SMART...
Would you have the ability to test this drive on another machine that has the same port type that you have problems with on this ASUS mb to see if the problem carries on with the drive onto another machine?
Maybe at your friend's house, work, local computer shop buddy, etc.
PostPosted: December 31st, 2011, 22:38
Hi all and happy new year!
I finally managed to confirm my problem was indeed a hardware problem with the said HDD!
Problem solved, thanks very much all for your help!
Users browsing this forum: No registered users and 307 guests
