 Post subject: Samsung HM501II
PostPosted: February 15th, 2012, 15:45
Hi, can anybody explain this log plase ?
Samsung HM501II, BIOS does not recognize HDD
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
˙˙˙˙*PA VID=0007 PN=0000 Rev=0004
                                                              ChipRev = 6B0
        U
S_0Shock Sensor Circuit Enabled
SO_1
IS=4
CLA #36/72
Handoff RPM=616
SPOK
mS1 00000003
A1O=127 A1G=445
O=511 S=4
SK C: 33968 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x17
ResoTable Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Loaded. Rev:0x02
Zh:0000005C Curr:0000007C
Zh:0000005C Curr:00000099
Zh:0000005C Curr:000000A6
Zh:0000005C Curr:000000A5
Zh:0000005C Curr:00000098
Zh:0000005C Curr:000000A3
|  19 | RLIST    |  2 | 0 |  468 | 1140 |
Zh:0000005C Curr:00000095
Zh:0000005C Curr:0000009D
Zh:0000005C Curr:0000008E
Zh:0000005C Curr:00000082
Zh:0000005C Curr:00000096
Zh:0000005C Curr:00000091
|  19 | RLIST    |  2 | 1 |  468 | 1140 |
Zh:00000060 Curr:00000096
Zh:00000060 Curr:000000A1
Zh:00000060 Curr:0000009B
Zh:00000060 Curr:000000A4
Zh:00000060 Curr:00000098
Zh:00000060 Curr:000000A3
|  19 | RLIST    |  2 | 2 |  468 | 1140 |
Reading Serial Num Pass
Up MC
PwrOn RRO1x @ H0
Table) cos = -224512, sin = -110336
Coeff) cos = -32909, sin = -27027
DiskSlip : 23 [SrvTrk]
DiskSlip : 27 [SrvTrk]
PwrOn RRO1x @ H2
Table) cos = -221696, sin = -108032
Coeff) cos = -21865, sin = -16183
DiskSlip : 25 [SrvTrk]
TgtCyl:     842
Hd:   0 Zn:   0 Avg.:-    140
TgtCyl:  174597
Hd:   0 Zn:   1 Avg.:     869
SVCAL(0080,0000)-->PASS
RecordValid Fail : 0107647D 0107E41D
EPOK
SoUL!
PK_4   C:  8496 H:0
Software unloading!
PK_4   C:  8496 H:0
LED 1A04
LED 1A04
 Post subject: Re: Samsung HM501II
PostPosted: February 15th, 2012, 16:41
That issue is related to a FW problem.
PostPosted: February 15th, 2012, 16:43
It's a firmware issue, can be fixed by pro with PC3000 UDMA latest version.
PostPosted: February 15th, 2012, 16:55
Yep. Just did not mention that :)
PostPosted: February 15th, 2012, 17:31
Beat me to it!! ;-)
PostPosted: February 15th, 2012, 17:58
Even without... :mrgreen:
PostPosted: February 15th, 2012, 18:01
Yes, that is true also! :-)
PostPosted: February 16th, 2012, 3:57
does the PCB replacement is a solution ?
HDD is under warranty but I need to recover data :roll:
PostPosted: February 16th, 2012, 4:21
I'm a peaceful guy, won't beat anyone :)
@cinerus: PCB replacement is not an option for this case.
If your data is really valuable you should go to a pro. At least you can get a quote.
PostPosted: February 16th, 2012, 7:43
PCB will not help
Assuming it is what we think it is, repair should be reasonable price.
PostPosted: February 16th, 2012, 12:49
Ok, thanks guys.
@dmarques
I can't send any message via PM.
Please mail me at
email removed
PostPosted: April 3rd, 2013, 13:08
ok i agree its a firmware problem
but how to solve it by terminal commands ?
S_0SSC EN
SO_1
SSC EN
IS=6
CLA #36/75
Handoff RPM=688
SPOK
SR:50 SS:00000280
mS1 00000003
A1O=1 A1G=431
O=511 S=1
SK C: 5987 H:0
CalibTable Loaded. Rev:0x1B
Fw Active 0000
Ovly loaded to 0x00014D00
Ovly loaded to 0x1002E300
| 19 | RLIST | 1 | 0 | 1270 | 1140 |
| 19 | RLIST | 1 | 1 | 1270 | 1140 |
| 15 | VLIST | 1 | 0 | 802 | 1140 |
Up MC
PwrOn RRO1x @ H0
Table) cos = 443904, sin = -530432
Coeff) cos = 28767, sin = -284792
DiskSlip : 74 [SrvTrk]
DiskSlip : 100 [SrvTrk]
TgtCyl: 832
Hd: 0 Zn: 0 Avg.:- 111
TgtCyl: 207552
Hd: 0 Zn: 1 Avg.: 1317
| 167 | DRM | 27 | 0 | 0 | 1140 |
RecordValid Fail : 4107647D 0107E41D
EPOK
SoUL!
PK_4 C: 10148 H:0
Software unloading!
PK_4 C: 10148 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
PostPosted: April 4th, 2013, 10:17
i can see firmware issue, ercoverable with pro tools
PostPosted: May 28th, 2013, 7:10
i managed to fix it by swamping another PCB with same ROM
Azzan Shahid
No one is master in this world but only His Almighty
www.datarecoverytanzania.co.tz
PostPosted: May 29th, 2013, 2:52
Unlikely.
PostPosted: May 29th, 2013, 3:29
It's not always for FW problem according to my experience.
It's sometime for A-LIST corruption, can be fixed without PC3K.
Sometime it's PCB failure.
I still have 1 case without solution (Under experiment if there is still other issue involved)
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 30th, 2013, 15:53
Finally the pending case is also solved.
__________
THANK YOU
SHAHI
PostPosted: May 30th, 2013, 16:23
hello shahij,
How did you manage to solve this two cases ?
Récupération de Données
PostPosted: September 10th, 2014, 5:35
I have this similar problem on a Samsung HM501II drive.
But Drive can not get Ready status.
When i power up the drive starts spinning and is clicking for about 5 min, then stops clicking sound and spin down
Any way?
I attach log.
Log100913.txt [196.65 KiB]
Downloaded 840 times
Users browsing this forum: Google [Bot] and 245 guests
