Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: Building powerful workstation , suggestions welcome
PostPosted: November 9th, 2011, 9:25
Nice Suggestion Crecomp,
It may help others who plan to upgrade / buildd new system.
PostPosted: November 9th, 2011, 9:28
crecomp wrote:
I Think you are better of to clone from ATA 0 to a network server, you can then have the other channel free to work with.
Cloning from ATA 0 or ATA 1 to the mainboard SATA channels may mean that you would need to either have your drives plugged in in advance or need to wait for an opportunity for a reboot to connect or disconnect drives.
Or you could just have a system with a eSATA or USB 3.0 external ports along with a docking station.
PostPosted: November 9th, 2011, 10:15
Cloning from ATA 0 to ATA 1 on PC3K is slow in a nutshell :)
PostPosted: November 9th, 2011, 18:05
Completely correct, but for peace of mind i like having redundancy so that when i make an image of a dying drive, i know my image is well and truly safe on a redundant system. if i loose 1 or 2 disks on our servers no issue.
All comes down to i guess what you have in place and personal preferences.
PostPosted: November 13th, 2011, 10:31
As far as PSUs are concerned, I simply can't recommend Seasonic enough. I like the modular M12II series and X series. They are not cheap but they are built like a tank, they provide a very stable output under any condition, they're efficient, they're quiet but most importantly, they're the most reliable I've come across.
PostPosted: March 2nd, 2012, 5:11
I'm bringing this thread to life again because we are considering upgrading our UDMA machines.
They are currently running on XP 32-bit and I was thinking of going to Win7 64-bit with i7 and 16GB memory, but i see UDMA does not support 64-bit (hence, max. memory 3.2GB). I read a thread in Ace forum about people asking for 64bit support but no response from Ace staff.
Anyone know anything new? Is it worth waiting a few more months maybe, or should i just bite the bullet and go ahead with a new solid 32bit machine with 3GB ram?
PostPosted: March 2nd, 2012, 5:41
I also built up a new UDMA machine recently and was keen to get loads of RAM in it, but ended up sticking with one 4GB DDR3 module as there is no 64-bit driver for PC3K so am stuck with Win 7 32-bit. No word from ACE on this that I have seen or heard.
Last year I started imaging from PC3K to drives connected via USB 3.0 but have found that, as fast as USB 3.0 is, it can be a bit flaky sometimes. I've since stuck in an add-on card that gave me an additional 4 SATA ports so these days I'm imaging from PC3K to drives connected to the host machine via SATA - no hassles.
Data Recovery Cape Town
PostPosted: March 2nd, 2012, 8:15
My PC is overkill but I have dual boot for win7 64 for personal use & gaming.
My specs are:
1080 HD TV
1Gb HDMI grapics card
15Tb - 5x wd 3tb sata3 greens - Raid5 setup - hooked up through MB to make use of the sata3 speed
AMD 960T Black Edition 3.0GHz quadcore (have tested overclocking to 4.2Ghz fine - but running it at normal speed as that is fast enough)
ASUS Crosshair V Formula 990FX Socket AM3+ 8 Channel audio ATX Motherboard (7 sata3 ports & plenty of usb3 ports)
Fractal Design Define R3 Black Pearl Case - USB3.0 front & back & esata port
2x G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit
Coolermaster Silent Pro Gold 1000W Modular PSU
OCZ 120GB Agility 3 SSD - SATA-III - Read 525MB/s Write 500MB/s with the OS on
Yes I know its overkill for my PC3000 UDMA & PC3000 Flash SSD but I am definatly a gadget boy :D & its future proof
Loki
PostPosted: March 2nd, 2012, 9:53
Loki, how do you run UDMA on a 64bit Win7 machine? Ace has not released drivers for PC3K card on 64bit.
PostPosted: March 2nd, 2012, 10:10
Think he dual boots x32 and x64, 32 for UDMA and 64 for gaming.
PostPosted: March 2nd, 2012, 11:02
Yep you got it :D
& with the SSD drive boot up is quick & as soon as you see the desktop I can start running programs etc.
Loki
Users browsing this forum: Google [Bot] and 91 guests
