 Post subject: How to make the writing of firmware in hd???
PostPosted: October 17th, 2005, 13:44
Which program I use to record firmware of the HD of the WD?
 Post subject:
PostPosted: October 18th, 2005, 9:03
PC3000
 Post subject: hi
PostPosted: October 18th, 2005, 10:11
when do live ?
sempre
 Post subject: Which program I use to record firmware of the HD of the WD?
PostPosted: October 18th, 2005, 14:43
Only exists an option? :o
 Post subject: FIRMWARES HDDS
PostPosted: October 18th, 2005, 14:54
clickclickclick
you already it used the PC3000? It serves for all marks and models of hds?
 Post subject:
PostPosted: October 19th, 2005, 2:21
There is a list of compatable drives on the PC3000 web site
 Post subject:
PostPosted: October 19th, 2005, 6:03
Is Fw same them Servo Information ? is the answer is yes you can use a sistem that the name is servowriter.
Is Fw same them BIOS upgrade ? if the answer is yes just go to the manufactur website and ask them they will provide you the best solution.
What are you looking for ?, really. Problem is who tell you that the problem in the disk is Firmware ? or what program/system did you use to have this diagnosis ? because same program/system can do the job. Or you just think that this is the problem ? Or you just hear that FW can be the problem ? Or you just knew ? because you are a genius.
Many questions, just write here that you need a solution and there is a lot of good and cleaver guys that will help you, me? I'm just an old singer of an old rock band.
 Post subject: Which
PostPosted: October 31st, 2005, 11:10
Seagate U8 Model ST38410A
P/N : 9P5002 - 003
Firmware : 3.03
Which one for Seagate firmware programs ? What is your programs name ? com port on or IDE on ?
 Post subject: you already used pc3000 pirate? it is good?
PostPosted: October 31st, 2005, 12:44
Você já usou o pc3000 pirata? é bom?
 Post subject: HRT
PostPosted: November 11th, 2005, 8:34
ALSO EXISTS HRT PCI SOMEBODY KNOWS OR ALREADY IT USED THIS TOOL?
WHICH ITS FUNCTIONS?
IT REALLY DECIDES?
IT CAN BE COMPARED WITH PC3000 ISA/PCI?
SOMEBODY CAN IN HELPING THEM?
 Post subject: Re: HRT
PostPosted: November 25th, 2005, 17:18
I was heard, HRT special soft for Seagate it better than PC3000.
Just use PC3000 if you want to repair MAXTOR and the other brand of HDD.
Just look carefully about the MODULE to use it.
Coz, wrong MODULE can make HDD become Broken or Fail.
Regards,
Along
HDD is a COMPUTER...
 Post subject: hi...
PostPosted: November 25th, 2005, 17:21
PC3000 sure.....
 Post subject:
PostPosted: June 17th, 2006, 7:16
pc3000 does not fix all drives it killed my 120gig seagate baracuda drive..the drive is in the dump now..
 Post subject:
PostPosted: June 19th, 2006, 18:34
a bad workman always blames his tools :shock:
A man is as old as he feels, and a woman as old as she looks
Users browsing this forum: Google [Bot] and 390 guests
