 Post subject: Head Donor compatibly WD20EARS-00MVWB0
PostPosted: April 27th, 2012, 5:57
Can someone from experience tell me is this close match or no, for head replace.
I have this WD drive, with bad heads.
WD20EARS-00MVWB0
Date: 17 may 2011
DCM: HHRNHTJMHB
DCX: 0M03V71W9
R/N: 771698
COUNTRY: THAILAND
Closest donor that i found localy is:
WD20EADS-22MVWBO
DCM: HBRNNTJMHB
DCX: 7M02V42W8
R/N: 771698
COUNTRY: THAILAND
Sistrum Data Recovery
http://www.sistrum.mk/en
 Post subject: Re: Head Donor compatibly WD20EARS-00MVWB0
PostPosted: April 27th, 2012, 6:16
http://www.dataclinic.co.uk/hard-disk-d ... bility.htm
Western Digital hard disk drives
Model
Firmware
In the alphabetic DCM code the sixth (and if you can the fifth, seventh and eigth) characters must match
PostPosted: April 27th, 2012, 6:41
Thanks Loki for your replay.
In my case only fifth don't match, 6th, 7th and 8th are same.
PostPosted: April 27th, 2012, 11:09
From my experience DCM doesn't matter too much in these newer WD series. I would say have a go with that donor.
Data Recovery Cape Town
PostPosted: April 27th, 2012, 13:02
Thanks Nick_CT
PostPosted: April 27th, 2012, 14:10
It's just not that simple anymore.
DCM, all of that is useless.
PostPosted: April 27th, 2012, 15:16
Yes, agree. Forget about DCM
PostPosted: April 29th, 2012, 11:10
Agree with above opinions.
but I doubt that the two drives have two different head map.
PostPosted: April 29th, 2012, 14:09
What's the result of head change?
PostPosted: April 30th, 2012, 5:59
I just finish with head change and start with data imaging. It is very slow.
PostPosted: April 30th, 2012, 17:27
did u check microjogs and/or made average and/or solve slow problem from solutions?
PostPosted: May 12th, 2012, 15:10
Hello Kum Ruzvelt, what was your reason for changing the head? Was your harddrive firstly not detected in the bios of your computer? I am having the problems with the same WD20EARS 2TB harddrive, see my topic at: not-recognized-harddrive-t22923.html .
Do you know a good tutorial on how to change the head?
PostPosted: May 13th, 2012, 12:32
Like I wrote in my first post, bad heads.
This is not a DIY procedure and for head replacement you should have a tools and clean room.
Users browsing this forum: Google [Bot] and 48 guests
