 Post subject: Seagate ST1500dl003 changhing PCB
PostPosted: May 21st, 2012, 2:55
i have a ST1500DL003 with a pcb issue.
i got a similar pcb for the drive and changed the ROM chip.
i get a error at the terminal:
"Flash boot code checksum failure!
SEA4 Boot ROM 2.0 (03/24/2009)
Copyright Seagate 2009"
I believe i solder the chip quit well. any ideas? Do you think i should try desolder and solder the chip again?
thank you
 Post subject: Re: Seagate ST1500dl003 changhing PCB
PostPosted: May 21st, 2012, 3:02
I attached a photo of the PCB. i marked 1 as the ROM chip. is the 2 chip has to be changed to?
thank you
WP_000111.rar [1015.56 KiB]
Downloaded 359 times
PostPosted: May 21st, 2012, 4:32
thank you
Only if it's faulty.
BTW, you really should invest in a better camera. Alternatively, tell us the markings on the chip.
PostPosted: May 21st, 2012, 5:24
thank you
IF PCB was compatible and there are other "sign" of work (*cough*) there is a certain probability they played with the drive and then sent to you or it was intentionally damaged. TO confirm , read the ROM externally and analyze it.
If it was screwed, you'll have to do your homework.... :mrgreen:
Users browsing this forum: Bing [Bot] and 97 guests
