Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: June 20th, 2012, 11:17
I dont know what is my password. :shock:
PostPosted: June 20th, 2012, 11:19
22.bin file help me get my passwords
00000000 55 00 01 00 00 20 00 64 00 00 BA 00 19 01 00 00 U.... .d..º.....
00000010 00 00 00 00 00 01 60 02 12 00 22 00 0A 00 00 00 ......`...".....
00000020 00 00 00 01 01 00 00 01 E0 01 0F 0F 01 02 02 0A ........à.......
00000030 01 02 00 02 02 08 01 00 FF FF 02 03 50 01 1E 64 ........ÿÿ..P..d
00000040 01 11 04 40 0B 02 00 01 00 00 00 00 05 00 00 00 ...@............
00000050 00 00 FF FF 00 00 00 00 12 0A 12 00 00 00 05 00 ..ÿÿ............
00000060 00 00 00 00 1E 00 00 00 00 00 00 00 00 00 4D 00 ..............M.
00000070 29 00 07 00 12 2E 00 00 00 0E 00 00 00 00 05 00 )...............
00000080 01 00 00 00 00 00 00 07 00 01 02 0D 00 01 03 00 ................
00000090 03 01 00 01 00 00 00 00 00 00 00 01 57 44 43 20 ............WDC
000000A0 57 44 32 35 30 30 42 45 56 54 2D 32 32 5A 43 54 WD2500BEVT-22ZCT
000000B0 30 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0
000000C0 20 20 20 20 20 20 20 20 00 01 53 7C 42 7C 4C 7C ..S|B|L|
000000D0 50 5A 4D 53 48 47 43 51 52 44 56 4D 4B 52 55 4A PZMSHGCQRDVMKRUJ
000000E0 00 20 20 20 20 20 20 20 20 20 20 20 20 20 30 38 . 08
000000F0 2D 32 32 2D 32 30 30 38 00 00 00 00 00 00 00 00 -22-2008........
00000100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ................
00000110 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000130 00 00 57 44 43 57 44 43 57 44 43 57 44 43 57 44 ..WDCWDCWDCWDCWD
00000140 43 57 44 43 57 44 43 57 44 43 57 44 43 57 44 43 CWDCWDCWDCWDCWDC
00000150 57 00 08 40 FE FF 00 01 00 00 00 05 00 64 00 14 W..@þÿ.......d..
00000160 20 32 00 00 00 0F 00 01 02 00 00 01 78 00 32 00 2..........x.2.
00000170 20 00 55 FF 00 01 00 00 00 00 00 00 00 00 00 00 .Uÿ............
00000180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 58 ..............XX
00000190 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
000001A0 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
000001B0 58 58 58 58 58 58 58 58 58 58 58 58 58 58 01 01 XXXXXXXXXXXXXX..
000001C0 01 01 01 00 00 00 00 00 00 00 00 00 00 01 FF FF ..............ÿÿ
000001D0 FF FF FF FF FF FF 00 00 00 00 00 00 00 00 80 00 ÿÿÿÿÿÿ........€.
000001E0 00 00 00 00 00 01 02 05 10 27 00 00 88 13 00 00 .........'..ˆ...
000001F0 00 00 D0 07 00 00 88 13 00 00 1E 00 00 00 05 D6 ..Ð...ˆ........Ö
22.zip [389 Bytes]
Downloaded 1141 times
PostPosted: June 20th, 2012, 11:27
Re-read & follow my post.
Your inputting a WD master password ie the WDCWDC bit without the ""
If you cant do this then you need to seek a pro.
PostPosted: June 20th, 2012, 12:27
Anyone got any advise for me? I am stuck...Plugged it into another laptop but MHDD doesnt see it. I dont see an option to change sata to ide in BIOS, would that be a problem here?
Please help...Dan
PostPosted: June 20th, 2012, 13:05
Please help...Dan
It might be called AHCI or Enhanced in BIOS.
You would need to change it to Compatible
Loki
PostPosted: June 20th, 2012, 18:14
Thanks mate but my BIOS have no option to change AHCI at all...But as far as I know that AHCI mode need to be set to IDE in order to MHDD recognise sata drives, I will try to pop in into my friends computer. Cheers, Dan
PostPosted: June 20th, 2012, 18:50
Compatible is the same as setting it to IDE
PostPosted: June 23rd, 2012, 10:41
I have WD5000AVDS and I have a problem with master password. I have tried unlocking with WDCWDC... and others similar.
I have tried using MHDD with two scripts for WD and WD Marvel. HDD was pluged either on SATA and SATA-IDE adapter. I have tested MHDD with scripts on three different PCs (gigabyte-k8ne, MSI-P45Neo and some old ECS-k7vta3).
I have successfuly test this one script and gets two .bin file.
; skriptas WDC sata rom  read
reset
waitnbsy
regs = $45 $0b $00 $44 $57 $a0 $80
waitnbsy
regs = $d6 $01 $be $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsfrom = rom128.bin
regs = $d5 $80 $bf $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = 2rom0.bin
waitnbsy
checkdrq
sectorsto = 2rom1.bin
; end
konfigūracijos sektorius rom128.bin 512 byte pirmieji 16 likusieji  00  0x 0000 24 00 01 00 00 00 00 00 00 00 02 00 00 00 00 00
but with these two scripts i have an error
23.06.2012  11:49:42   MHDD>PORT
23.06.2012  11:49:45   Changing mode to: IDE
23.06.2012  11:49:45   Device selected: 10
23.06.2012  11:49:54
23.06.2012  11:49:54   MHDD>EID
23.06.2012  11:49:54   WDC WD5000AVDS-63U7B1  LBA: 976,773,168
23.06.2012  11:49:54   SN: WD-WCAV9L605016  FW: 01.00A01
23.06.2012  11:49:56
23.06.2012  11:49:56   MHDD>.WD
23.06.2012  11:49:56   MHDD ATA/SCSI TERMINAL v2.1
23.06.2012  11:49:56   Script: WD
23.06.2012  11:49:56   LINE 1: RESET
23.06.2012  11:49:56   LINE 2: WAITNBSY
23.06.2012  11:49:56   LINE 3: REGS = $57 $44 $43 $00 $00 $A0 $8A
23.06.2012  11:49:56   LINE 4: WAITNBSY
23.06.2012  11:49:56   LINE 5: REGS = $00 $02 $00 $00 $0F $E0 $21
23.06.2012  11:49:56   LINE 6: WAITNBSY
23.06.2012  11:49:56   LINE 7: CHECKDRQ
23.06.2012  11:49:56   ERROR: No DRQ
23.06.2012  11:49:59
23.06.2012  11:49:59   MHDD>.WD1
23.06.2012  11:49:59   MHDD ATA/SCSI TERMINAL v2.1
23.06.2012  11:49:59   Script: WD1
23.06.2012  11:49:59   LINE 1: RESET
23.06.2012  11:49:59   LINE 2: WAITNBSY
23.06.2012  11:49:59   LINE 3: REGS = $45 $0B $00 $44 $57 $A0 $80
23.06.2012  11:49:59   LINE 4: WAITNBSY
23.06.2012  11:49:59   LINE 5: REGS = $D6 $01 $BE $4F $C2 $A0 $B0
23.06.2012  11:49:59   LINE 6: WAITNBSY
23.06.2012  11:49:59   LINE 7: CHECKDRQ
23.06.2012  11:49:59   LINE 8: SECTORSFROM = CS.BIN
23.06.2012  11:49:59   ERROR: drive reports error
in Zu got something similar to:
ERR:51E0EB14000304 CMD:0000000000E0EC
in mavr_r something like (I dont remember):
(many readings)
... 00 bytes recived
Can you tell me what should be in cs.bin, please? In which sector password is saved?
(I made cs.bin in hex editor)
PostPosted: June 23rd, 2012, 12:53
I don't see any option to edit my previous post.
I pluged HDD WD5000AVDS-63U7B1 (FW: 01.00A01) by SATA-IDE adapter to IDE1 as primary channel.
zu /p
ERR:51A00000434404 CMD:5744430000A08A
ERR:51A00000B40F04 CMD:D601BE4FC2A0B0
mavr_r 00
Module Id:FFH Len=0000H Sectors Status=040FB4-51-51
00H Modules Are Founds
PostPosted: June 23rd, 2012, 17:40
I'm not a 'data thief', I've bought this HDD about two weeks ago on http://www.allegro.pl (something like ebay). The HDD is from some PVR (Cyfra+). I didn't supposed that I would have a problem with using this HDD with PC. I ask seller about password and he answered that he never set password and this HDD is from Pace PVR HD HDS7241/91CD. I can return this drive and get my money back but i would prefer to keep it because it was cheaper than others 500GB drives, thats the reason I choose it. Like I said I bought it about two weeks ago so I don't have much time to send it back. And before I will do it I want to try every free possibilities to unlock it.
So far I tried unlock it with MHDD, ATAPWD, HDDErase using many passwords like combinations of WDC, wdc, nbox, TEAMASSEBLY, h2oinsyde.
I think that i made everything right to get password (script, cs.bin 512bytes by HEX editor, using MHDD4.5, plug disk by IDE) but i don't have results, just errors every time I try.
Could you explain to me what is REGS = $57 $44 $43 $00 $00 $A0 $8A for?
I think that $57 is for W, $44 = D and $43 = C so it is for finding specific place on disk.
But in second script we have REGS = $45 $0B $00 $44 $57 $A0 $80, why it's so different?
It' some kind of offset?
What it is for 'sectorsfrom = cs.bin' ? Why it is 0x000 08 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 ?
Why we have repeated twice the same commands in script and results save to different files?
regs = $d5 $01 $bf $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = 21.bin
waitnbsy
checkdrq
sectorsto = 22.bin
Where should I look for password? Is it elsewhere in my WD5000AVDS?
Why do i get an error message?
Please help me a little. I promise i will not ask to decode my pass like others do ;-) I think I can do that last thing by myself if I only get this script to work.
And please don't leave me with advice to use HDDUnlock because it cost about 20% of my monthly earnings and it's more than I spent on this HDD :-/ Yep I'm from Poland.
PostPosted: June 25th, 2012, 5:28
Success, I finally did it! :-)
The third version of ZU worked for me (zu.betta.050911), almost gave up. It was a nice surprise to see "UNLOCK DONE".
MHDD shows that the password is off. Then I had a problem with formating drive in Windows disk management and other partition tools but MHDD coped with this (I've used commands CLRMBR and FDISK) and now i can use WD5000AVDS in my PC :-)
Thanks for this thread. I still wonder what was the default password used by this PVR because WDC.. didn't worked.
Have a nice day everyone :-)
File comment: ZU that work with wd5000avds-63u7b1
zu.betta.050911.rar [4.13 KiB]
Downloaded 2003 times
PostPosted: June 25th, 2012, 7:50
Well done mate. I have been watching your posts closely but as I have no experience in this sort of situation I kept quiet. Just a quickie for you, is ZU simillar to MHDD? I mean do I lauch it in the same way and run scripts? Cheers, Dan
PostPosted: June 26th, 2012, 16:42
Hello Everyone,
I'm sure I am not the first person who has managed to password lock their WD my passport external hard drive and forget it.
Can anyone please advise me how i can get the bin files as I do not understand how to,even though i read the many threads that are posted.
Thank you in advance
Feel free to contact me by email:tanyakolieva@gmail.com
PostPosted: June 27th, 2012, 3:28
sweetdevil777888 wrote:
Hello Everyone,
Sorry but the way your thinking wont work as that is for a hard drive password set in BIOS.
Im assuming you set the password via wd smartware software. Correct me if i am wrong.
If so then there is no free way to unlock your drive & keep your data. Unless you remember your password.
There are a few members here that can unlock a smartware password for a price and is safe to the data stored. Otherwise your other option is to format the drive, lose the data & move on.
Loki
PostPosted: June 27th, 2012, 5:33
Hello
This is the result of script 'dump'
Still, I don't see what the password can be ? Tried this on a locked WD2500JS.
00000000 00 00 00 00 00 00 00 01 5A 02 23 00 22 00 0A 00 ........Z.#."...
00000010 00 00 00 00 00 00 00 00 00 00 00 01 E0 01 0F 0F ............à...
00000020 01 02 02 0A 01 01 01 02 02 10 01 02 FF FF 05 00 ............ÿÿ..
00000030 50 01 00 01 02 02 00 00 00 00 01 00 00 00 00 05 P...............
00000040 00 00 00 00 00 FF FF 00 00 00 00 12 0A 12 00 80 .....ÿÿ........€
00000050 00 05 00 00 00 00 00 1E 00 00 00 00 00 00 00 00 ................
00000060 00 4D 00 29 00 07 00 12 00 00 00 00 0E 00 00 00 .M.)............
00000070 00 00 00 00 01 00 00 00 00 00 00 07 00 01 02 0D ................
00000080 00 00 00 00 00 00 00 00 00 01 04 00 03 01 00 01 ................
00000090 00 00 00 00 00 00 00 00 00 00 00 00 00 01 57 44 ..............WD
000000A0 43 20 57 44 32 35 30 30 4A 53 2D 35 35 4D 48 42 C WD2500JS-55MHB
000000B0 31 20 20 20 20 20 00 00 00 00 00 00 00 01 53 39 1 ........S9
000000C0 42 41 4C 4D 50 46 4D 35 48 55 43 35 52 55 56 46 BALMPFM5HUC5RUVF
000000D0 4B 4C 55 4B 00 20 20 20 20 20 20 20 20 20 20 20 KLUK.
000000E0 20 20 30 36 2D 32 37 2D 32 30 30 37 00 00 00 00 06-27-2007....
000000F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000100 00 00 00 00 00 00 00 00 00 01 0F 00 AD 44 47 65 ............­DGe
00000110 A4 AD 5D 4E 67 32 D7 65 67 44 0E AB D3 1B 83 90 ¤­]Ng2×egD.«Ó.ƒ.
00000120 57 C6 0C A9 28 7F 19 DA 25 0D 6D 3E 69 74 61 20 WÆ.©(..Ú%.m>ita
00000130 73 74 61 74 69 63 20 69 6E 69 74 20 70 73 20 77 static init ps w
00000140 64 20 6F 6E 20 66 6C 79 20 74 65 00 08 00 FD FF d on fly te...ýÿ
00000150 00 00 00 00 00 01 3C 00 00 F4 01 C4 09 0A 20 00 ......<..ô.Ä.. .
00000160 00 00 00 00 00 01 C8 00 B4 00 32 00 20 00 55 FF ......È.´.2. .Uÿ
00000170 00 00 00 00 00 00 00 01 46 00 00 00 45 00 00 00 ........F...E...
00000180 44 00 00 00 43 00 00 00 42 00 00 00 41 00 00 00 D...C...B...A...
00000190 00 01 36 00 00 00 35 00 00 00 34 00 00 00 33 00 ..6...5...4...3.
000001A0 00 00 32 00 00 00 31 00 00 00 00 01 26 00 00 00 ..2...1.....&...
000001B0 25 00 00 00 24 00 00 00 23 00 00 00 22 00 00 00 %...$...#..."...
000001C0 21 00 00 00 00 01 16 00 00 00 15 00 00 00 14 00 !...............
000001D0 00 00 13 00 00 00 12 00 00 00 11 00 00 00 00 00 ................
000001E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000001F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
PostPosted: June 27th, 2012, 5:40
narcotrix wrote:
Hello
Oops, when booting this morning, I noticed my hd is missing in bios (the field is blank)
I did start mhdd en this is the log of problem...
[PRE]
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY AMNF T0NF ABRT IDNF UNCR BBK 04
[ ] [ 0] [ ] [ ]
LBA:0 BIOS: 83H
SN: FW: Size = 0MB
IMPORTANT NOTICE: This device does not
support LBA mode. MHDD will NOT work with this device.
To see enhanced information, use command EID <SHIFT+F2>
Init drive: [RECAL]
RECAL FAIL
I guess something went wrong...
PostPosted: June 27th, 2012, 10:01
IMPORTANT NOTICE: This device does not support LBA mode. MHDD will NOT work with this device.
Both of these symptoms show that the current problem with the drive is not (or not only) an ATA password being set. If you need the data from this drive, then IMHO you'll likely have to send the drive to a suitably-experienced professional for accurate diagnosis and recovery.
PostPosted: June 27th, 2012, 15:08
Thank you Loki for your answer. Yes i have indeed put a password via the smartware software. I am just glad there is a way. How much does it cost and who can do it?Also please tell me ur location.
PostPosted: June 27th, 2012, 15:26
You could try contacting einstein9, pcimage or DR-Kiev here on this forum all are respected members
Loki
PostPosted: June 27th, 2012, 16:11
Hello Gurus, I am stumped and having the same problem as quoted below. The drive is a WD1000BEVS that was in a Gateway laptop that has died, so I have the drive hooked up to another PC (via SATA cable, set to IDE compatibility mode). Password was set at BIOS level and I already knew the password ("debbie55"), but I ran the MHDD script anyways just to confirm, and what what little knowledge I have from reading this thread, it looks like that's right (except it's padded with 00's). MHDD/HDAT2/Victoria show the security level as "High". I want to avoid a "destructive unlock" since I actually need the data on this drive. The master password revision code is FFFEh.
I've tried converting to decimal and then holding alt-gr and typing it out, and it does type out the password, but the unlocks still fails. If there is another way of entering the PW or sending the PW to the drive (Victoria for Windows?) I am unsure how to do it and would appreciate any help. It looks like the user 'subspace3' got the same problem resolved but did not post how :/ I know I'm probably missing something obvious...
Attached is my 22.bin
subspace3 wrote:
Hi all,
I really hate to do this but wondering if someone could pm or post on here what I need to know.
Basically found an oldish laptop in my work which may have important data on it. Boss wants me to look anyway and thinks the hdd was locked by the last IT guy who left a while ago. This laptop is dead but putting it into mine I've managed to run MHDD and the dump script to get the 22.bin file. (See below)
Now I'm thinking the user password is 02 0A 05 08 1F 26 and the master
04 24 16 23 09 15 07 24 is this correct? Basically looking for the 01 07 00 and taking all the hex values up to when the 00 's start and then taking the other values after this until the 00's start again as the master password, is this correct?
If so how do I get these into passwords I can enter into MHDD to unlock the drive? I've tried converting to decimal and selecting alt gr when typing each 3 digit part but nothing types in. Also tried an hex to ASCII and tried those values after dispwd command also. No joy. Also converted the hex to keyboard scan codes and used them In MHDD and Victoria with still no success?
Any body know what I'm doing wrong? I tried saving the HEX selections using ultraedit and then selecting those files in victoria security manager to unlock the hard drive but it doesn't seem to send the anything from the file.
Used this guide (translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http://elettrofreak.blogspot.com/2011/02/estrarre-le-password-ata-da-un-hard.html)
00000000h: 3C 55 00 01 00 00 20 00 64 00 00 BA 00 19 01 00 ; <U.... .d..º....
00000010h: 00 00 00 00 00 00 01 60 02 12 00 22 00 0A 00 00 ; .......`..."....
00000020h: 00 00 00 01 03 01 00 00 01 E0 01 0F 0F 01 02 02 ; .........à......
00000030h: 0A 01 02 00 02 02 08 01 00 FF FF 02 03 50 01 1E ; .........ÿÿ..P..
00000040h: 64 00 11 04 40 0B 02 E8 03 64 00 00 01 00 00 00 ; d...@..è.d......
00000050h: 00 05 00 00 00 00 00 FF FF 00 00 00 00 12 0A 12 ; .......ÿÿ.......
00000060h: 00 00 00 05 00 00 00 00 00 1E 00 00 00 00 00 00 ; ................
00000070h: 00 00 00 4D 00 29 00 07 00 12 2E 00 00 00 0E 00 ; ...M.)..........
00000080h: 00 00 00 05 00 01 00 00 00 00 00 00 07 00 01 02 ; ................
00000090h: 0D 00 01 03 00 03 01 00 01 00 00 00 00 00 00 00 ; ................
000000a0h: 01 57 44 43 20 57 44 33 32 30 30 42 45 56 54 2D ; .WDC WD3200BEVT-
000000b0h: 37 35 5A 43 54 32 20 20 20 20 20 20 20 20 20 20 ; 75ZCT2
000000c0h: 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 ; ...
000000d0h: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
000000e0h: 00 00 01 00 01 53 7C 42 5A 4C 7C 50 4D 4D 46 48 ; .....S|BZL|PMMFH
000000f0h: 47 43 4A 52 4E 56 4D 4B 51 55 41 00 20 20 20 20 ; GCJRNVMKQUA.
00000100h: 20 20 20 20 20 20 20 20 20 31 31 2D 32 32 2D 32 ; 11-22-2
00000110h: 30 31 30 00 00 00 00 00 00 00 00 00 00 00 00 00 ; 010.............
00000120h: 00 00 00 00 00 00 00 00 00 00 01 07 00 02 0A 05 ; ................
00000130h: 08 1F 26
00 00 00 00 00 00 00 00 00 00 00 00 00 ; ..&.............
00000140h: 00 00 00 00 00 00 00 00 00 00 00 00 00 04 24 16 ; ..............$.
00000150h: 23 09 15 07 24
00 00 00 00 00 00 00 00 00 00 00 ; #...$...........
00000160h: 00 00 00 00 00 00 00 00 00 00 00 00 00 08 40 28 ; ..............@(
00000170h: B5 00 01 30 00 00 05 00 64 00 14 20 32 00 00 00 ; µ..0....d.. 2...
00000180h: 0F 00 01 02 00 00 01 78 00 32 00 20 00 55 FF 00 ; .......x.2. .Uÿ.
00000190h: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ; ................
000001a0h: 00 00 00 00 00 00 00 00 00 58 58 58 58 58 58 58 ; .........XXXXXXX
000001b0h: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 ; XXXXXXXXXXXXXXXX
000001c0h: 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 ; XXXXXXXXXXXXXXXX
000001d0h: 58 58 58 58 58 58 58 58 58 01 01 01 01 01 00 00 ; XXXXXXXXX.......
000001e0h: 00 00 00 00 00 00 00 00 01 30 30 5A 43 30 30 37 ; .........00ZC007
000001f0h: 35 25 00 01 00 01 00 00 00 00 00 00 00 00 00 00 ; 5%..............
HDD: WDC WD3200BEVT-75ZCT2
Thanks for any help!
Users browsing this forum: No registered users and 72 guests
cron
