 Post subject: Close enough DONOR
PostPosted: August 6th, 2012, 22:55
Hi experts. Just wondering what the closest compatible donor for head swap on WD10EADS-00L5B1, DANNNT2MBN, Kermit series drives. They are so hard to come by.
Really more so for my training. Part of my task is that i've been given a handful of drives by my instructor and i'm there to get it to an operable state. I do have access to to the lab & tools.
PM if you could assist. thanks. Could any of the Kermit series work? Again if its a little hush, PM me please..
thanks. DEN
 Post subject: Re: Close enough DONOR
PostPosted: August 6th, 2012, 23:04
What Kermit donors do you have?
PostPosted: August 7th, 2012, 4:42
So far I can only identify these:
WD10EAVS-00D7B1
WD10EVDS-00N581
WD10EAVS-32D7B1
WD10EACS-00D6B0
Can someone enlighten me about "fixing up DAC values" on the heads preamp else in some donor heads you will damage it if you leave it on for too long without adjustment". Preamp will start to emit high pitch sound which indicates a damaged preamp. My brain just doze off track. Does this make sense?
PostPosted: August 7th, 2012, 8:54
http://www.donordrives.com/hard-drive-p ... swap-match
PostPosted: August 7th, 2012, 9:19
yep. got that info already. just been reading around here seeing people being able to use parts that doesn't follow that rule. I guess either people are that secretive or nobody have had to dig into it. Time to get into more trouble.. ahh the pain of learning. Lets ruin more drive and see. I just hope my instructor doesn't dig into these forums.
PostPosted: August 7th, 2012, 9:23
Are all the drives new or used but in good working condition?
One thing that seems secretive or omitted on purpose on your end is why your instructor (suppose data recovery instructor) does not explain what is/not compatible so that things do not get ruined?!?
Kermit are ok. Many are compatible among each other. However though they are compatible on paper, there is compatibility issues with heads.
DCM is not extremely important.
PostPosted: August 7th, 2012, 10:22
ah yes thats a good query.
instructor wants to know our base knowledge to get an understanding of where we are at. Its actually part of a course i've been assigned to do. Forensics. Only 4 of us. So you can say i'm a trainee.
PostPosted: August 7th, 2012, 12:25
Hi, then you have nothing to loose. Let insructor do his/her job based on accurate evaluation.
PostPosted: August 7th, 2012, 14:10
Wondering what his base knowledge is?!? Why? Because this is a very "advanced task/question to answer" to expect of somebody who is just a trainee
Can you name what forensics course this is? I may be interested in attending.
I really hope you reply.
If not comfortable with telling publicly, send me a PM with answer.
Thanks in advance.
PostPosted: August 7th, 2012, 18:43
Match heads map and microjogs.
http://www.datasaversllc.com
PostPosted: August 7th, 2012, 20:08
Thanks in advance.
part of Computer Crimes unit. Unfortunately you'll have to be an officer already.
PostPosted: August 7th, 2012, 20:09
have you had to change dac values?
PostPosted: August 7th, 2012, 20:12
instructor aint available for this task. you could say this is our homework.
edit:
nothing to loose except for a head stack. Just averaged microjog was able to access SA. Could't access filesystem. Each attempt it does a hard reset. Unfortunately after leaving it for 20mins powered accidentally (went for lunch), classic , now i can hear high pitched noise and drive is now clicking :(. i assume preamp is dead. As we've been warned.
i honestly think this was meant to happen.
PostPosted: August 10th, 2012, 2:42
Are you experimenting on New or Damaged drives? If old drives, you will most likely loose more head stacks if don't bother looking at surface damage. Check all platters under microscope for debri, scratches, etc. You can kill heads pretty quickly if surface has physical damage. High pitched noise to me indicates an overheated preamp. Don't think there's anything related to the dac tables you are referring to if you are say SA was accessible after a head change but you left it 20mins then heads died.
You are working on a clean room right?
Users browsing this forum: Google [Bot], Stritom and 297 guests
