 Post subject: Hard drive won't spin
PostPosted: July 30th, 2012, 19:49
Banned User
Hi guys,
I need your help as I has got a problem with the hard drive. Few months ago the hard drive was working fine when I was working on it to get the partition table to restore as it has been corrupted due to raw format. When I ran the test disk, it took me ages to complete the method to restore the partition but I doesn't realised that the hard drive started to stop working when the recovery program did not complete the process to recover the partition.
I have had a look at the PCB board to find out why the hard drive won't spin. I suspected that the spindle motor wiring on the PCB to engaged with the motor axis to allows the platters to spins, is burnt.
Here's the picture:
I would like to get advice how I can measure the PCB board using with the digtal multimeter.
Can you please tell me how I can measure the PCB board using with digital multimeter to find out whether if the spindle motor wiring or the PCB board is dead??
Any advice?
 Post subject: Re: Hard drive won't spin
PostPosted: July 31st, 2012, 11:58
Can you tell us if your drive spins up at all?
If it does not, simply replace PCB with compatible PCB.
I should have this PCB in stock if you need it. Just provide a picture of the front label.
www.datarecoveryne.com
PostPosted: August 7th, 2012, 15:04
Banned User
hello,
no my drive don't spin up at all.
do you know if the PCB or the motor is dead?
PostPosted: August 7th, 2012, 15:06
99.9% PCB at fault, not motor.
PostPosted: August 7th, 2012, 15:10
Banned User
thanks for your quick reply. How do you know that the PCB is fault?
When I took measurement on the PCB used with the multimeter, there are no resitance at all.
PostPosted: August 7th, 2012, 16:19
Just because I have refurbished several thousands of that model drives and have not seen many with failed motors.
PostPosted: August 8th, 2012, 15:42
Banned User
Oh ok, how much are you selling for the PCB replacement?
Here is my specifications:
Code: NAR61HA0
Four chartcher: KMGA
Model: 6K040L0
PCB number: 040122600
PostPosted: August 10th, 2012, 12:35
Banned User
@harddrivespecialist: how much are you selling for the PCB like the one I have got?
PostPosted: August 10th, 2012, 17:10
Code: NAR61HA0
Model: 6K040L0
Almost certainly will have one of these, have at least 1000 of these old Maxtor drives :-)
Email me Monday to remind me, and one is yours for £20 all in delivered!
Obviously can't guarantee it will fix your drive, but worth a shot!
PostPosted: August 13th, 2012, 10:38
Good offer, would go with it.
PostPosted: August 13th, 2012, 19:08
Banned User
@harddrivespecialist: did you get my pm?
i need your answer plz thanks!
PostPosted: August 14th, 2012, 9:59
You have been offered a replacement PCB from a reputable member who is closer to you, and it is offered at a bargain price, and you still want to get a price on it from USA, where I am sure you would have to cover international shipping costs? :?:
PostPosted: August 14th, 2012, 16:59
Banned User
Yeah but I need to know if the PCB would work from a different model but come with a same code like this:
Code: NAR61HA0
Four chartcher: KMBA
Model: 6E040L0
PCB number: 294932005
Here is my PCB:
Code: NAR61HA0
Model: 6K040L0
If I get a PCB that come with a same code but come with a different model, would it work?
I need to know, because i have found cheap PCB which it would cost me £9 for replacement.
I'd hope that it will work as long I have get the same code as my original drive.
PostPosted: October 17th, 2013, 0:55
Hi there,
Would you mind telling me the hard drive brand and model shown in the picture? I'm using the same motor for a school project and I need more information about the BLDC motor (e.g. RPM, current, volts, etc).
Thanks in advance, and best regards!
-Al
PostPosted: October 17th, 2013, 1:48
The following datasheet for an L7250 motor controller might be of use to you:
http://pdf.datasheetcatalog.com/datashe ... Xyuswx.pdf
It should help you understand how these motors work.
You might find something here as well:
http://www.users.on.net/~fzabkar/HDD/HD ... ntrol.html
Users browsing this forum: Rendersmith and 97 guests
