 Post subject: ST9640322AS not recognized by bios
PostPosted: August 24th, 2012, 12:26
My Atola device thinks that is is a failed head stack or possibly electronics. Typically when it is a headmask error I will validate it with the terminal error. I have not seen this error prior. My research points to firmware issue possibly. Any idea on this error?
Atola terminal output:
Rst 0x08M
LED:000000CC FAddr:00258097
Just keeps repeating the led error
:shock: :shock:
 Post subject: Re: ST9640322AS not recognized by bios
PostPosted: August 24th, 2012, 15:17
Rst 0x08M
:shock: :shock:
Does it sound perfectly normal? Steady spin with no spin down or speed variations?
PostPosted: August 24th, 2012, 20:09
I would say like Sean said, if it spins down, almost certainly it's heads.
PostPosted: August 27th, 2012, 9:27
At power on - the drive clicks a few times and then spins steady. At first it was just beeping. I took into into the clean room and moved the heads back to the parked position. The the drive clicked a few times and then spins up.
Thank you for your thoughts!
Doug
PostPosted: August 27th, 2012, 9:31
So that seems that had stiction, but now heads are ruined. Are all heads attached to the arms?
PostPosted: August 27th, 2012, 9:38
all the heads appear to be attached. The heads we originally positioned at the edge of the platters. I just spun the disk counter clockwise and moved the heads back into the ramp.
PostPosted: August 27th, 2012, 9:41
So I'm almost sure they are damaged.
You need to check them and replace.
PostPosted: August 27th, 2012, 9:56
Thank you for your feedback. I will replace them and see how it goes!
Thanks everyone!
Users browsing this forum: Google [Bot] and 271 guests
