 Post subject: Damage Fujitsu hard drive to repair
PostPosted: September 2nd, 2012, 12:23
Hi
I have got an Fujitsu 120GB 2.5" IDE hard drive. Model Number: MHT2120AT. The hard drive 5 volts got connected to 12 Volts and an IC on the PCB has Blown. Does anyone know what the IC is and can I replace it?
The IC is next to the coil and is an 8 pin IC - I think it is an voltage regulator???
I have attach an image of the PCB
Also there is an short between the 5volts to GNd
thanks
 Post subject: Re: Damage Fujitsu hard drive to repair
PostPosted: September 2nd, 2012, 12:58
Check TVS or replace the entire PCB with matched one and transfer the original ROM to the donor PCB.
Good luck
PostPosted: September 2nd, 2012, 13:46
Try to check the fuse.
Bosse
[img]
[/img]
http://www.rescue-it.se
PostPosted: September 2nd, 2012, 17:10
Hi
Thanks for the info.
The fuse is ok. I think the isue is the IC near the coil
does anyone know what the IC is and where I can get a replacement
