 Post subject: Toshiba MK6465gsxn 2.5" drive
PostPosted: September 4th, 2012, 15:42
I had a drive with electronics failing per atola device. I acquired a donor. I tested the donor and it passed diags. I transferred the ic602 chip to the replacement board via air solder station. When I fired up the transferred board, the drive no longer spins. I moved the ic602 chip back to the original board and get the same results. Is there fuse on this board? any advice would be apprecialted! :?
 Post subject: Re: Toshiba MK6465gsxn 2.5" drive
PostPosted: September 4th, 2012, 18:40
Do you mean you moved the donor's IC602 back to the donor's board and no longer spinning the donor drive?
Did anything happen with the ROM? Any of the contacts (legs) broke?
PostPosted: September 5th, 2012, 5:02
First of all you should use terminal to decide whether PCB is good or bad and whether Flash is OK.
PostPosted: September 5th, 2012, 5:16
Are you soldering skills up to the job?
Data Recovery Cape Town
PostPosted: September 7th, 2012, 14:38
its very easy to kill em 2.5 boards by overheating.
Users browsing this forum: No registered users and 62 guests
