 Post subject: WD1600JD Showing Zero Capacity - Unable to read ROM
PostPosted: September 13th, 2012, 15:16
Any hope with this? The drive comes ready, recognizes the full model and serial number, but shows 0 LBA and is completely inaccessible. Also it fails when trying to read ROM, and none of the system area modules are visible. I've tried a different PCB, hoping there was a slim chance that might have been the issue, but same result. Any thoughts on what else I might try with this? Feel free to PM if you prefer. Thanks!
WD1600JD-75HBB0
 Post subject: Re: WD1600JD Showing Zero Capacity - Unable to read ROM
PostPosted: September 13th, 2012, 16:15
What fw tool you using?
If its UDMA then it sounds like you're selecting the wrong family utility.
PostPosted: September 13th, 2012, 16:21
HD Doctor
PostPosted: September 13th, 2012, 16:49
Havent used my hd doctor for years, but are you sure you are selecting the right family?
PostPosted: September 13th, 2012, 22:41
Positive. I even tried similar families just to be sure. On DDI it shows all details for the drive but then has 0 LBA and then below that it says ZERO CAPACITY. Everything sounds normal with the drive.
PostPosted: September 14th, 2012, 5:08
HB = Falcon family
PostPosted: September 14th, 2012, 8:31
WD1600JD-75HBB0
Any signs that this drive may have gone to some other "funny" places prior to you? Or what is the history on the drive?
PostPosted: September 14th, 2012, 10:58
As far as I know, it was sent to us shortly after it failed. I can only go by what the customer says. Is it possible that if they did a straight swap with a very close match on the PCB you might get these same results? I guess I've never swapped a PCB without swapping or reprogramming the ROM, so I'm not sure.
PostPosted: September 14th, 2012, 11:01
loki wrote:
HB = Falcon family
No, it is Eagle family.
OP, you could try moving the ROM to an IDE Eagle PCB. IIRC Salvation tools interact weirdly with the SATA WDC drives.
PostPosted: September 14th, 2012, 12:55
That was one of the first things I tried when I was working with different PCB's. Same result.
PostPosted: September 14th, 2012, 13:10
Weird. Sounds like hotswap time then.
Users browsing this forum: Google [Bot] and 212 guests
