 Post subject: WD passport essential problem
PostPosted: September 17th, 2012, 14:47
Hello everyone,
I have WD passport essential 500gb USB 3.0, When I plug the USB cable in my laptop even any pc the light comes on and Windows recognizes that the device is there, and says that it has installed the approapriate software for the device and it is ready to use meanwhile its searching driver to installing. after sometimes its showing in my computer as CD Drive (F:). Also, I have right-clicked on my computer and then the Manage option, and under Disk Management but this page is not opening only after disconnect the usb cable its showing disk drive page.
for your information i have attached some necessary screen shot... I just need some help on how to solve this problem.
thanks & best regards
File comment: when i try to open disk managment its showing in the bottom... connecting to Virtual disk services... and standby like this only but after disconnect the usb cable this page opening immediately.
File comment: showing in control panel - device and printer
File comment: after plug in the cable
 Post subject: Re: WD passport essential problem
PostPosted: September 17th, 2012, 17:16
hi,
what kind of sounds do you hear when you plug in the disk?
the motor stay on or after a while spin down?
Italian Recovery - Italian Data Recovery Company
http://www.italianrecovery.it
PostPosted: September 17th, 2012, 18:37
I think your drive may be failing, so if your data is valuable I wouldn't much things with it and consider going to a pro to get a proper diagnosis and quote.
Anyway, might help answering to the questions above.
PostPosted: September 18th, 2012, 2:07
italian-recovery wrote:
hi,
When i plug in the disk there is sound of spin but after few second spin down and again same things happened 2-3 times then no sound at all, but the lights still on
PostPosted: September 18th, 2012, 2:34
hi,
Bad heads
Physical problem
No DIY :-(
PostPosted: September 18th, 2012, 3:11
hi,
Bad heads
Physical problem
No DIY :-([/quote
Could you please help me to get my data from hard disk
Thanks & regards
Jewel
PostPosted: September 18th, 2012, 3:16
Where are you located?
PostPosted: September 18th, 2012, 3:25
I am in jeddah, KSA.
Regards,
Users browsing this forum: No registered users and 58 guests
