 Post subject: Old Toshiba MK431Mat firmware problem
PostPosted: September 17th, 2012, 10:53
Hello i have a Old Toshiba MK431Mat with firmware problem ( i suppose translator problem)but pc3 doesn't support this model (as well as Salvation data) Any suggestions?
 Post subject: Re: Old Toshiba MK431Mat firmware problem
PostPosted: September 17th, 2012, 11:55
First question: how do you know it's a firmware problem? How did you reach that idea?
PostPosted: September 17th, 2012, 12:12
I have access to the HD, I can see the root and all files, but if I try to extract them from the hard disk, this files are all damaged except very small files. It seems the translator classic problem.
PostPosted: September 17th, 2012, 12:20
Well, I don't think translator problem is so classic on Toshiba drives, but I may be missing something.
Also, are you sure you can read the whole contents of the file? Have you tried to check them with a hex viewer to see if they have contents?
PostPosted: September 17th, 2012, 12:25
I did not mean that the translator problem is a classic thing about toshiba but that is similar to the translator problems of the other disks.
You've read the contents and files with winhex and it have content, but there are strange characters in the header.
PostPosted: September 17th, 2012, 18:27
I see.
And have you checked if your sectors are being read correctly or read with ECC errors?
PostPosted: September 18th, 2012, 2:39
Hi, i try this option with cloning option DDI and let you know
PostPosted: September 18th, 2012, 3:21
Ok. Let's wait for your answers.
PostPosted: September 18th, 2012, 11:48
Also with this way, i have the same result: all file is damaged :-(
PostPosted: September 18th, 2012, 11:50
Well, without checking it I can't help much more, as we would need to be sure about it.
PostPosted: September 18th, 2012, 11:54
ok thanks for your suggestions
PostPosted: September 18th, 2012, 12:17
Sounds like 'LBA shifting' to me, not fw
Don't know much without diagnosing the drive
Users browsing this forum: Google [Bot], michael chiklis and 223 guests
