 Post subject: 300GB SAS shows 140
PostPosted: February 2nd, 2013, 9:01
Dear Experts (specially Doomer)
i got 4 SAS drives (seagate) in RAID, but noticed this issue which is strange really
SAS Controller reports correct size, but Windows reads it as 140GB
the problem is this applies to ALL 4 drives, not only one, which i suspect here
any clues...
thnx
 Post subject: Re: 300GB SAS shows 140
PostPosted: February 2nd, 2013, 9:31
So this is not problem with the drives themselves.
Therefore IMHO much more detail needed about:
- the RAID configuration;
- exactly where you are looking when you say that "Windows reads it as 140GB";
- details of customer's original SAS controller and any RAID features;
- what exact problem the customer reported;
- what steps led up to this situation.
I don't understand what specifically you are referring to when you say "which i suspect here" - what are you suspecting and why?
Good luck!
PostPosted: February 2nd, 2013, 10:11
Thnx Vulcan for the reply
I meant in windows like DM, or Winhex, or any tool reads as 140gb
and when trying to READ those 140GB, PC hangs with NO BAD SECTORS reported in events viewer
and suspicion here is that the problem of Size applies to all drives not only 1
PostPosted: February 2nd, 2013, 10:43
Better do a full disc clone of all 4 before going further.
http://www.rescue-it.se
PostPosted: February 2nd, 2013, 11:23
@einstein9,
Thanks for that info. As mr_spokk says, cloning would be a good idea - but of course all 300GB needs to be recognised & cloned by whatever cloning tool you use.
Personally I would also need the answers to my other questions which you didn't answer, before I offered any suggestions (as I would need those answers in order to avoid giving bad advice, which is why I asked the questions ;) ). The troubleshooting plan in my head at the moment may be changed, depending on those other answers...
Anyway, good luck with this interesting problem.
PostPosted: February 2nd, 2013, 14:30
As the controller reports right size, and Os +SW don't...I would Image the drives in an "non" Os depended SW...Like mediatoools or similar.
PostPosted: February 2nd, 2013, 14:59
Agreed (if the HBA has its BIOS extension enabled) :good:
I think there may also be another easy option, but I'm waiting on answers to the earlier troubleshooting questions, so hopefully I avoid making bad suggestions...
PostPosted: February 2nd, 2013, 19:34
What model of SAS are these?
PostPosted: February 3rd, 2013, 2:56
@ guru, Model: ST9300605SS
@ Vulcan, Raid5, client reported 3 hdd`s in server LED Blinks (reports errors)
@ Spildit & mr_spokk any access to hdd will hang the PC, booting is FINE into windows
as an update to this case, I managed to clone 1 (took full day - more or less) COMPLETE IMAGE...
thank you :wink:
PostPosted: February 3rd, 2013, 8:01
If you got min>maxlba no problem :)
PostPosted: February 3rd, 2013, 8:17
thank you :wink:
How and what did you use to clone the drives?
PostPosted: February 3rd, 2013, 12:52
Spildit wrote:
mr_spokk wrote:
thank you :wink:
It shouldn't take that long to clone just one drive.
Probably not if it was a healthy drive, but chances are that it wasn't healthy, given that it is in for recovery. :D
PostPosted: February 3rd, 2013, 13:07
:wink:
PostPosted: February 4th, 2013, 13:41
Problem Solved.....
Case closed...
happy ending..
:mrgreen:
PostPosted: February 4th, 2013, 13:45
einstein9 wrote:
happy ending..
Do you charge extra for that?
PostPosted: February 4th, 2013, 16:23
drc wrote:
einstein9 wrote:
happy ending..
Haha
All the "extras" !!
PostPosted: February 5th, 2013, 3:46
hehehe
Well i like it when you face a problem for the 1st. time and you are able to find the solution for it in a short time
paying our school fee`s
:wink:
Users browsing this forum: Google [Bot], SRUTSSSSSSSS80 and 112 guests
