 Post subject: Samsung HD321KJ
PostPosted: March 12th, 2013, 9:36
Drive came in and was clicking, swapped heads and same results, put the clients heads in parts drive, drive comes ready and I can read, put heads back in patient drive and I get this via terminal, could someone give me some idea of what it's wrong with this drive? thank you in advance
SPW 1.5G LinkOk! ADC: FFFE
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: FFFF
DAC: A594
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
WriteSctLog -- buffer not valid
LED 13 0000
LED 13 0000
 Post subject: Re: Samsung HD321KJ
PostPosted: March 12th, 2013, 9:45
If those heads work in donor drive, I would say scratch on patients platter.
Was the drive dropped?
http://www.rescue-it.se
PostPosted: March 12th, 2013, 9:50
no dropped, at least that what the client claims, i had swapped PCB and heads and can get access to the module to be able to fix SA if something it;s wrong with drive. No scratches on platters
PostPosted: March 12th, 2013, 10:20
This is the 1 platter version...right? So you can see if head1 surface is damaged?
Could be a microscopic scratch...did you try hotswap as well?
PostPosted: March 12th, 2013, 10:39
2 platters, looked under microscope no scratches on ether platter, I had tried hotswap heads just sweep the platter and does no come ready, I'm baffle with this behavior, swapped heads again and both clients and parts heads still good :-?
thank you for your replay mr_spokk
PostPosted: March 12th, 2013, 11:00
put part heads again and now I get this on terminal and drive spins down
SPW 1.5G LinkOk!RS-5
RS-5
RS-5
RS-5
RS-5
ADC: 0063
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0067
DAC: F3A8
UF 1 AccTOErr
H: +00001
UF 1 AccTOErr
H: +00002
UF 1 AccTOErr
H: +00003
UF 1 AccTOErr
H: +00000
UF 1 AccTOErr
H: +00001
UF 1 AccTOErr
H: +00002
UF 1 AccTOErr
H: +00003
UF 1 AccTOErr
H: +00000
UF 1 AccTOErr
H: +00001
UF 1 AccTOErr
H: +00002
UF 1 AccTOErr
H: +00003
UF 1 AccTOErr
H: +00000
UF 1 AccTOErr
H: +00001
UF 1 AccTOErr
H: +00002
UF 1 AccTOErr
H: +00003
UF 1 AccTOErr
LED 13 0000
LED 13 0000
LED 13 0000
LED 13 0000
LED 13 0000
LED 13 0000
LED 13 0000
LED 13 0000
PostPosted: March 12th, 2013, 11:31
Have a feeling : is the PCB native ? ;)
PostPosted: March 12th, 2013, 11:44
Put client PCB on parts drive, drive comes ready with correct parts' s /n, FW, MDL and capacity, so I can rule out the PCB, I will try another head xplant
PostPosted: March 12th, 2013, 11:55
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: FFFF
DAC: A594
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
H: +00000
UF 3 1stGrayErr
H: +00001
UF 3 1stGrayErr
H: +00002
UF 3 1stGrayErr
H: +00003
UF 3 1stGrayErr
LED 13 0000
LED 13 0000
cut it short to the end = HEADS
good luck
PostPosted: March 12th, 2013, 12:08
With new set of heads, drive clicks and spins down, I put the clients heads on my parts drive and parts drive comes ready and reads from all 4 heads, very frustrating, no cigar!
thank you to all who replied to my issue
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: FFFE
DAC: A594
Unlatch Tk: 00015CA5
Unlatch Done
ENG>SRV>Tgt Tk:00000000 Hd:00 SkRetryCnt:+00000
AP_TO
C: 000005DC H: +00000
AP_FSAM
C: 0000E508 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016C5E
Unlatch Done
SvoTbl Loaded
à Q 6 n Iñ ÿ V 8 $ * V 8 $ *``ppÀà0``ppÀà0``pÀÐð@``ppÀà0`ppÀà`ppÀà=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu BF
AP_TO
AP_FSAM
C: 0000DAEB H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016EE8
Unlatch Done
AP_EST
Tgt Tk:00000000 Hd:00 SkRetryCnt:+00001
AP_FSAM
C: 00028AC6 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016C44
Unlatch Done
AP_TO
AP_FSAM
C: 0000DE76 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016DB9
Unlatch Done
AP_TO
AP_FSAM
C: 0000D9B8 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016D46
Unlatch Done
AP_TO
AP_FSAM
C: 0000DC81 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 000169D8
Unlatch Done
AP_EST
AP_FSAM
C: 00019E96 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016B31
Unlatch Done
Tgt Tk:00000002 Hd:00 SkRetryCnt:+00000
AP_TO
C: 000005EC H: +00000
AP_FSAM
C: 0000DE09 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 0001692A
Unlatch Done
AP_EST
Tgt Tk:00000002 Hd:00 SkRetryCnt:+00001
Unlatch Tk: 0001F812
Unlatch Done
AP_TO
AP_FSAM
C: 0000DFAB H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016E02
Unlatch Done
AP_TO
AP_FSAM
C: 0000D7B9 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016D24
Unlatch Done
AP_TO
AP_FSAM
C: 0000D63B H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016ABF
Unlatch Done
AP_EST
AP_FSAM
C: 0001C904 H: +00000
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 00016B5C
Unlatch Done
LED 14 0000
LED 14 0000
LED 14 0000
LED 14 0000
PostPosted: March 13th, 2013, 3:59
@OP
You have PM
PostPosted: March 14th, 2013, 15:53
Thank you for all the help, drive couldn't be recovered, the servo was lost on the drive no matter how many compatible heads and pcb swapped I was never able to access SA no even in burn mode, my first experience with a Samsung having this symptoms...
Users browsing this forum: Bing [Bot] and 238 guests
