 Post subject: HUMAX media center HDD (ST3160215ACE & ST3160212ACE)
PostPosted: March 21st, 2013, 12:14
I have two hard drives pulled from a HUMAX media center and they have high secutity settings with a user password. I tried SeDIV but it doesnt have these model numbers. I can connect to it via terminal, but since the certificate is missing, I cannot type the commands required for a user pw reset. Is there any other way to breathe life into these babies? The data is not needed.
 Post subject: Re: HUMAX media center HDD (ST3160215ACE & ST3160212ACE)
PostPosted: March 21st, 2013, 20:14
Okay, here is the first one:
Reset
1024k x 16 DRAM
NHAWK - 1_Disk    S-42   04-06-07_14:29
Buzz HM SFI
(P)PATA Reset
Master
:5000000803000001  AX`9RX2NSNA'  "000000000000"138F9-13A76
SRAM Ovly = AT
PostPosted: March 21st, 2013, 20:21
What do you mean by "click on"?
PostPosted: March 21st, 2013, 20:26
Okay, here it is:
BT:0000
PC:0056
AP:0060
RL:0298
AL:029B
SL:02B3
MW:0367
AT:038B
TB:038B:0020
SO:03AB:0039
FS:03E5:0038
RD:0480:0010
WR:0490:0010
FM:04CD:0018
AD:04CD:001C
BA:04E5:0003
ST:04E8:0001
AS:04E9:007F
DP:0568:02A6
AC:0568:02A6
SC:080E:02A7
CT:0B60
uP:0FC0
MZ:0FC0
logbps :0200
codebps:0200
PostPosted: March 21st, 2013, 20:34
So far all done :).
PostPosted: March 21st, 2013, 20:42
It's mr. ST3160215ACE
PostPosted: March 21st, 2013, 20:45
It just gave back the 2> prompt, there was no output.
PostPosted: March 21st, 2013, 20:50
Looks like some kind of repeating pattern :P.
buffer 0490   comparing to 0490  RD:04AD:10:00  WR:04BD:10:00
Addr  0 1 2 3  4 5 6 7  8 9 A B  C D E F 10 1 2 3  4 5 6 7  8 9 A B  C D E F
092000 EF7FFFBF 9FF7BFD7 FFFFFFDF DFEFFBFF DDBFBFFF FBFFFB7B FFFE7FB7 6E7FFFFD
092020 BB9FFFDF BBBFBFF9 FFFF7FFB FEFBFFFF DBBFBFEB FFFFFFEF FFBF7FEF FFFD9FEB
092040 BFEBFFFF FFFFFFEB BFFBB7DF FBFF31BF FFFFFFFF FFFEB7FF 5FDFFBF9 BBD7BFFF
092060 FFFF7B7F FF97FFDF 7FEFFFED FFF3F9FB BEFFFFFE BFFDF7FF FFFDDEDF FBFFFFEF
092080 BFF93BFF B7DFFFFB BBFFFFFF FFFEFBDF BFF7FBFE BFFFBDFF FBFEBFBF 77FFFFE7
0920A0 FFF7BFF3 FAFFBFFD BFF7FFF3 FFEF7FDF FFFBFFFF FFB7B3FF F7FFFF7B 7FFFFFDF
0920C0 BFBFFBFF BFF7FFEB DFFFB7FF FFDFBFFB DAFDFBF7 FFFFFFFD FFDFFFFF 3FEFFB6F
0920E0 FFFFB7DB FB8FFBBB FFFBFFFF 7FFFFFF7 BFF6FFFF F7FBBBFF FFF7BFFB FFFFFFFF
092100 BFDB77FF FBF3F77D FFFFFFEB BFBB7F5B FBFB7FFF 7FFFFFF7 FFFFFFFB FFEFFFF7
092120 BFFBF7FF DBFFBFFF DF6FABFB FBFFFFDF BBFFFBEF FFFFFFFF FF7F7FFB FBEFDFFF
092140 BFFFFBEF FFFBFF5F FBDF3FDD FDFFFF7F FFFF77FF B7FFFFFF FBFFFFFF BFF7F7FB
092160 FFFFFFDF BFF7F7FF FEDF9FDF FBBFFFFF BF9FEFEF FFDFF7FD BFEEBBFF FEF6BFFF
092180 FFFFF7B7 BFFF77FF FFFFFFFB FBFBF7EF FDFDBFDF FBFBBFDF FAFFFBFF FFE7FF5F
0921A0 EB7BFFBB FF7FBFE7 BBFBBBDF FFBFF7DF BFF7FFDF FFDFF7FF FBBFFFFF DFFFF7DF
0921C0 FFD1FFFF FFFFBBFF FBFFFFEF FFFBFFF7 7BFADBDF B7D6BFBF BFFDFFDF BFFF7FFF
0921E0 B7FBFFFF 7FFFFEFF BFEBFFFF 7FFDF6FF DF6FFFFF BFFFDFFF 7FFF77FF FFFFFFFD
092200 00001102 10820001 02000041 00000003 00002100 00200012 00100180 00000000
PostPosted: March 21st, 2013, 21:17
I'm here, just tried all the sectors, but basically they output the same pattern with some minor differences at the end. Too bad I have to repower for each attempt.
PostPosted: March 21st, 2013, 21:19
Btw, you are god! I'll check it out with the other drive meanwhile.
PostPosted: March 21st, 2013, 21:29
Oh, I've got the nasty bastard :).
PostPosted: March 21st, 2013, 21:47
I don't know if I can post the pass (board rules?), but after the ascii treatmeant the result was some garbled mincemeat. Your method worked like a charm!!!
PostPosted: March 21st, 2013, 22:26
Damn, life is not easy :D. On the other drive, I find the sector, overwrite it with the 00 value, write the buffer out, but after reset it reverts back to its original 01 state. In this case, I have to give the pass in hexa format to some hdd util, like HDAT2 or MHDD?
Users browsing this forum: No registered users and 167 guests
