Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: OCZ Vertex 2 240GB SSD for recovery
PostPosted: April 4th, 2013, 13:00
i still testing SSD.
now i can not get output by tx/RX port.
any idea?
thanks
PostPosted: April 4th, 2013, 13:16
If you know how to use a multimeter, I can show you the voltage test points.
PostPosted: April 4th, 2013, 13:43
sure please, let me know
thanks fzbkar
PostPosted: April 4th, 2013, 14:16
There should be +5V at the F1 solder pad near the SATA power connector.
Check the +3.3V pin at the JTAG connector.
Check the outputs of the coils L1 and L2. The associated circuits look like buck regulators. I believe they will be providing +3.3V and Vcore (1V - 2V).
There is also an IC on the other side (U22) that I can't recognise. It would help a lot if you could zoom up on the affected areas, and provide me with the chip markings.
PostPosted: April 4th, 2013, 14:21
BlackST
Have a Q for you here about SSD, if you ever had this problem
Phoenix Pro SSD (SandForce), working means detecting and reading OK
but Unable to FORMAT it or RE-USE IT
kind of Stuck somewhere (which i dono where really) but looks Intresting really
when its DETECTING but unable to:
1- Format it
2- Copy Anything TO IT - but can TAKE FROM IT
looks very Strange
if this damn SSD was a HDD, i would think of many reasons, but as an SSD, nothing
btw, i tried many formatting tools such as:
1- HDDScan
2- Guru - LLF
3- Windows format
all of those shows formatting progress, i leave it for a while then i stop it
then when i disconnect n reconnect it back, Damn it, everything comes back like NO ONE DID ANYTHING TO IT
i was laughing today about it, but really never had similar case like this, and i assume you too
let me know my dear
:wink:
PostPosted: April 4th, 2013, 14:24
AIUI an SSD becomes readonly when it runs out of spare blocks. Did you check the SMART attributes?
PostPosted: April 5th, 2013, 4:04
Thanks fzabkar for your tips, ill make new pics and upload it.
PostPosted: April 5th, 2013, 8:27
Hi fzabkar
I atach better pics
PostPosted: April 5th, 2013, 8:54
hi fzabkar,
I suppose that F1 solder pad is the site of a fuse
But this not here
You think must be a fuse?
PostPosted: April 5th, 2013, 15:48
einstein9 wrote:
BlackST
1- Format it
looks very Strange
1- HDDScan
2- Guru - LLF
3- Windows format
let me know my dear
:wink:
See it at least 2-3 per month and increasing (I still wonder why people are buying SSDs :( ). PM me.
PostPosted: April 5th, 2013, 16:02
I bought a batch of 64GB USB thumb drives that are known for this issue...wish I had known before wasting my time on them. Just in case you are wondering, I don't recommend Hip Street branded 64GB USB thumb drives.
einstein9 wrote:
BlackST
1- Format it
looks very Strange
1- HDDScan
2- Guru - LLF
3- Windows format
let me know my dear
:wink:
PostPosted: April 5th, 2013, 16:37
Turned into RO ?
PostPosted: April 5th, 2013, 17:18
But this not here
The location for F1 (yes, it is a fuse) has been left vacant because the design allows for R1 or F1 but not both. The only reason I asked you to measure the voltage at that point was that it is more accessible than R1.
Coils L1 and L2, plus their associated "OFA" ICs, constitute two switchmode regulators. The voltages at the coils will be the outputs of the regulators.
TPS62065, Texas Instruments, marking OFA, 3-MHz 2A step down converter:
http://www.ti.com/lit/ds/symlink/tps62065.pdf
I can't make out the markings on the IC at U7, but it appears to be a POWR607. Its function is to monitor and sequence the onboard power supplies and to provide a watchdog timer to reset the controller in the event that the firmware gets stuck in a loop or the controller hangs.
ispPAC-POWR607, Lattice Semiconductor, Programmable Power Supply Supervisor, Reset Generator and Watchdog Timer:
http://www.latticesemi.com/dynamic/view ... t_id=21806
I'm a bit concerned about the "stuff" in the top right corner of the IC. It could be a manufacturing mark (the IC is in-circuit programmable), but I'm not sure.
The IC monitors 6 voltages (at pins 1,2,4,5,6,7), but the circuit is suggesting that there are actually 4 voltages being monitored. I would measure the voltages identified in the attachment.
I can't make out the markings on U22, but the logo looks like it belongs to Fairchild, so it appears to be a power IC of some kind. Could you tell me its markings?
PostPosted: April 5th, 2013, 17:52
The IC monitors 6 voltages (at pins 1,2,4,5,6,7) ...
Sorry, that pinout is for a different package. The actual voltage monitor pins (VMON) are 2,3,5,6,7 and 10.
PostPosted: April 6th, 2013, 5:17
einstein9 wrote:
BlackST
1- Format it
looks very Strange
1- HDDScan
2- Guru - LLF
3- Windows format
let me know my dear
:wink:
In fact i got it as a Gift from one of my friends for my Research, and was wondering if someone had it before with SSD
BlackST
And i`ll be sending it to one of my friends here for more Diagnose since he loves those stuff,
thank you
PostPosted: April 6th, 2013, 17:49
BlackST wrote:
Turned into RO ?
Yup. I was transferring client recovered data to the key as a destination drive and the process failed mid stream and boom! I could only read the data. This happened with 2 of out of 2 keys. I did a google search and found that almost 100% of the reviews reported the exact same symptoms.
PostPosted: April 7th, 2013, 11:35
But this not here
Thanks fzabkar for your clever advices
I am not in work and i can not see PCB but ill take a characters and report here .
L1=0,97V
L1=2,79V
about other voltages
Fuse pins to ground = 4,9V
JTAG P1 to ground = 3,22V
about the "stuff" i'll verify it but looks like a factory mark (any cain metalik ink) or maybe "tin waste". but not sure i have not the ssd here now tomoorow i'll verify it
correct: The actual voltage monitor pins (VMON) are 2,3,5,6,7 and 10.
i'll test from points to ground
[/quote]
I'll read i t for you
thanks another time
PostPosted: April 7th, 2013, 16:51
hhddrec wrote:
L1=0,97V
L1=2,79V
I presume the two L1 readings actually refer to L1 and L2. If so, then the 2.79V reading must be the supply for the NAND flash array, and 0.97V must be the Vcore supply for the SandForce controller.
If so, then the JTAG supply must be coming from some other IC, possibly U3 near the SATA power input (or U22).
In any case, 2.79V is too low for the NAND array. My searching suggests that the OCZ M2502128T048AX22 NAND flash parts are rebadged Micron MT29F128G08CFAAAWP chips. These are 3.3V, 128Gb, 16G x 8 parts.
If this measurement is correct, and if my analysis is correct, then the POWR607 chip is probably holding the SF-1222TA3-SBH controller in a reset state.
Can you tell me the markings on U3 and U4?
Could you also measure the resistances of R4, R5, R22, and R23? These will allow us to calculate the correct supply voltages for the "OFA" regulators.
PostPosted: April 7th, 2013, 17:50
If the 2.8V reading is correct, then check each of the NAND flash chips for heating. One or more of them may be pulling the 3.3V supply down. Otherwise there could be a problem in the Vio section of the controller.
PostPosted: April 8th, 2013, 1:09
The problem is in any case elsewhere.
But be real : if one of the flash is broken, if the controller is broken/malfunctioning, and if the circuit is malfunctioning without knowing how it works (and expensive tools) no amount of tinkering will get a a byte out of it. Also, there's encryption to deal with. Good luck.
Users browsing this forum: mima85 and 46 guests
