 Post subject: barracuda st3500320as donor ?
PostPosted: June 20th, 2013, 7:32
hello friends ;
i have got a
seagate barracuda
st3500320as
S/N: 9QM8GMJS
P/N: 9BX154-303
DATE CODE : 09174
SITE: KRATTSG
producing a sound when powerd u , and doesn't get ready in ddi
terminal log is
LED:000000CC FAddr:0024A051
the drive doesn't power down untill i power it down ..
i suspect the heads . and found an expected donor for it
MAXTOR DIAMONDMAX
st3500320as
S/N: 9QM20GJ4
P/N: 9GT154-325
DATE CODE : 08383
SITE: KRATTSG
what do u think abut the problem ? and if it is heads , is the donor drive considered a good donor ?
thank you
 Post subject: Re: barracuda st3500320as donor ?
PostPosted: June 20th, 2013, 10:55
This is typical BSY bug. Nothing to do with heads.
PostPosted: June 20th, 2013, 11:00
dear ;
at my knowledge , busy bug doesn't prevent the drive from ID ...
this drive doesn't ID at all
thank you
PostPosted: June 20th, 2013, 12:50
good evening again ;
sorry , i may misunderstood u .
it is the BSY bug , but i handled several similar drives with BSY bug , there didn't have this kind of noise ...
PostPosted: June 20th, 2013, 14:54
Test the heads in terminal
PostPosted: June 20th, 2013, 16:11
F3 T>/7
F3 7>X
LED:000000CE FAddr:0028E24B
PostPosted: June 20th, 2013, 19:18
And does not spin down?
PostPosted: June 21st, 2013, 3:50
nop ..
i started thinking that the drive did has the BSY bug at first and user tried several things to get his daa back , so that he ruined his drive more ...
PostPosted: June 21st, 2013, 4:43
You're wasting your time.
is the BSY bug.
PostPosted: June 21st, 2013, 5:14
+1 for BSY
http://www.rescue-it.se
PostPosted: June 21st, 2013, 6:15
is the BSY bug.
sirs ;
the drive does has the BSY issue , but there must be something else ..
the drive produces a sound " each time powered on "
the sound is attached ..
no scratches sound , it just produce a noise
thank you again
Sans titre.zip [963.97 KiB]
Downloaded 472 times
PostPosted: June 21st, 2013, 10:20
is the BSY bug.
sirs ;
thank you again
I would say is the BSY bug too.
But hearing this sounds, maybe stucked heads, or any other problem in heads, maybe in platters
PostPosted: June 21st, 2013, 12:52
there is difinately something else other than BSY , even trying to clear SMART "a very simple R/W operation" will make the drive produce the noise again ..
heads are not stuck , does the donor i have presents a good head replacement one ?
thank you
PostPosted: June 21st, 2013, 14:15
Donor is compatible
PostPosted: June 22nd, 2013, 13:26
scratches on the surface :cry:
donor heads act just like the patient heads ......
thank you all for your help
Users browsing this forum: No registered users and 30 guests
