Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: BARRACUDA 3TB PCB + BIOS SWAPPED!
PostPosted: July 22nd, 2013, 0:11
It's much more than 50$ as you have to send your UNIQUE PCB to USA or CHINA at your own risk with a reliable courier. At least from Italy it is gonna cost you from 28 to 70 EUR depending on vector for standard shipping (3-5 working days). Unless you send it as ISF (good luck!) to spend 10/15 Eur.
PostPosted: July 31st, 2013, 17:58
hi, i have resolder the bios chip now better, but the HDD is NOT SPINNING! ;(
PostPosted: July 31st, 2013, 18:17
Do you have a multimeter?
Can you upload complete photos of both PCBs?
If you are not prepared to take some measurements, then at least try to obtain a serial terminal report. If the MCU is alive, then it will tell you if the "ROM" is OK.
PostPosted: August 2nd, 2013, 13:17
ok i will asap!
Users browsing this forum: No registered users and 43 guests
