Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: seagate st1000dl002 busy
PostPosted: May 21st, 2013, 4:19
BUSY, cant access SMART in MHDD.
Heads ?
terminal:
Boot 0x20M
Spin Up[0x000246DF]
Trans.
Rst 0x20M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 00999A80 00000000 00133350 00000000 00000000
MC 00000000 0098A120 00000000 00131424 00000000 00000000
MSP 009917E0 00000BE0 001322FC 0000017C 000003CB 00000001
User Partition 00999A80 00133350 000003C0 00000001
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40134924 40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
Footer - start: 0000122D end: 00001254
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00366DD7
[RSRS] 07D6 DiscLba 00044908 RW_RTL FFFFFFFF
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000210 DBA Base 40000000
Metadata size in bytes 0040
Num Segments 005F
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 001322FC BlkSize 00000BE0 Num Segments 0000005F DiscLba 001322FC RW_RTL 000F4240
No valid segments found
MSP MSP Main Store Verify Reconstruction Status 10003000
Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 001322FC DiscSize 0000017C PhyBlkLBA 009917E0 BlkSize 00000BE0
Write MSP Segment PhyBlkLBA 009917E0 BlkSize 00000BE0 DiscLba 001322FC RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
ScratchPad restore NOT required
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
(DOS)STE OGHT: 0x051CCBE1 - 0x051CE803 - 0x00013873 - 0x00013887 Count 006A
(DOS) Refresh Start.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F0!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F1!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F2!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F3!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F4!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F5!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F6!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F7!.
(DOS) Read Error -
InitiateMarkPendingReallocateRequest for disc_lba: 051CD7F8!.
(DOS) Read Error -
 Post subject: Re: seagate st1000dl002 busy
PostPosted: May 21st, 2013, 5:31
What did you/the owner do BEFORE ?
PostPosted: May 21st, 2013, 6:06
Before BUSY it slowed down.
PostPosted: May 21st, 2013, 7:04
I mean if there was some 'internet magic commands' action, or shocked, or...
PostPosted: May 21st, 2013, 7:25
T>i4,1,22
and
1>N1
PostPosted: May 21st, 2013, 13:14
before (N1 and i4,1,22) end of log was a little different
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
PostPosted: May 21st, 2013, 18:07
Spildit wrote:
kowalski wrote:
means ?
You have used a fix for 7200.11 BSY/LBA 0 on a drive that have firmware prior to F3 arch.
7200.11 and newer drives will identify at terminal as F3 T> and NOT T>
The commands for those drives are diferent.
On a F3 arch drive F3 1>N1 will clear SMART and F3 T>i4,1,22 will erase G-LIST.
But your drive is prior to F3 arch and so the commands that are valid for that drive type are the following :
http://malthus.zapto.org/viewtopic.php?f=6&t=2
Doing I at level T on a drive prior to F3 will "Cert the reserved Cylinder" ...
I think that your firmware is gone now .... Drive can't read Firmware because .... it's gone ... or so i think.
Initial problem with the drive could have been a weak failing head or damage (bad sector) on a specific part of SA.
Do you have tools like PC3K, Salvation or STR ? If so it might still be possible to upload to the drive a copy of the firmware and Self Scan it. Of course you will loose all the data.
All this on a ST1000DL002 ? 8)
PostPosted: May 22nd, 2013, 0:58
Even worse, also this assumption to me is wrong.
Probably it was a relatively simple problem in the beginning, the disk just needed to be cloned safely after stabilizing the Fw and then eventually refurbished. Now I would only trust PC3000...
PostPosted: May 22nd, 2013, 4:09
It's still visible in MHDD and BUSY (like before N1 and i4,i,22)
After about 2 hours of "InitiateMarkPendingReallocateRequest for disc_lba" still visible in MHDD and BUSY.
After reconnecting in terminal it shows the same log, but without "InitiateMarkPendingReallocateRequest for disc_lba" (like in the beginning).
Boot 0x20M
Spin Up[0x000246DF]
Trans.
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
(DOS) Read Error -
So from the terminal point of view and MHDD behaviour nothing's changed.
PostPosted: May 22nd, 2013, 8:12
hi
i think this drive should be a GRENADA family -ROM LUXOR (maybe luxor_2_1).
why not to try to stop relocation through CONGEN?
after you can check lists for pending sectors and try to read (in ESLIP mode if needed)
hope this can help
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: May 22nd, 2013, 8:37
Thank you.
I've read somewhere about it, but i can't find proper instruction.
I think it should be something like: T>Fsomething
PostPosted: August 26th, 2013, 16:36
T>Fxxxx,yy
where xxxx is the flag address, yy is the value you want to change the flag to. It even spells out all the flag values. Use F alone to list flags, F with addr to list that flag address, and with value in hex at yy to modify.
Look at the top of F listing, the first set is what you probably want to modify, RWRecoveryFlags. Names should be pretty self explanatory.
PostPosted: September 2nd, 2013, 15:19
Hello
I have a similar issue on a friends disk
Seagate Barracuda Green 2TB
st1000dl001
Wont show passport etc as wont come ready
Busy signal stays green for 15 seconds or so, then does go not-busy
Serial connection (38400)
power on
after a few seconds get the following
Rst 0x20M
RW: Disc Ctlr Initialization Completed.
(P) SATA Reset
then nothing
no respose to ctrl-Z
But if wait a few minutes, get
ASCII Diag mode
F3 T>
/2 works to get to F3 2>
but not planning to do anything for a while until I can remember any non-destructive commands
No LED error, so not sure what to try first
Thanks for any suggestions
PostPosted: September 2nd, 2013, 15:35
F3 T>
; gives Invalid Diag Cmd
. gives
F3 T>
Current R/W User LBA 000000000000 LLL CHS 000000.0.0000 PLP CHS 000000.0.0000
R/W Status 1 R/W Error 00000080 Ready
? gives
Blks 001445-001445 (000001), BufAddr 00288A00-00288BFF, DBA 40288A00, BytesPerBlk 200 Cmd Input Buf
Blks 001446-001446 (000001), BufAddr 00288C00-00288DFF, DBA 40288C00, BytesPerBlk 200 Diag Batch File
Blks 001447-001447 (000001), BufAddr 00288E00-00288FFF, DBA 40288E00, BytesPerBlk 200
Blks 001448-001448 (000001), BufAddr 00289000-002891FF, DBA 40289000, BytesPerBlk 200
Blks 001449-001449 (000001), BufAddr 00289200-002893FF, DBA 40289200, BytesPerBlk 200
Blks 00144A-00144A (000001), BufAddr 00289400-002895FF, DBA 40289400, BytesPerBlk 200
Blks 00144B-00144B (000001), BufAddr 00289600-002897FF, DBA 40289600, BytesPerBlk 200
Blks 00144C-00145F (000014), BufAddr 00289800-0028BFFF, DBA 40289800, BytesPerBlk 200 Online Cmd SDBP DFB
Blks 001460-001473 (000014), BufAddr 0028C000-0028E7FF, DBA 4028C000, BytesPerBlk 200 Test Service SDBP DSB
Blks 001474-001487 (000014), BufAddr 0028E800-00290FFF, DBA 4028E800, BytesPerBlk 200
Blks 001488-00149B (000014), BufAddr 00291000-002937FF, DBA 40291000, BytesPerBlk 200
Blks 00149C-0014E3 (000048), BufAddr 00293800-0029C7FF, DBA 40293800, BytesPerBlk 200 Diag Mode Cmd SDBP DFB
Blks 0014E4-00152B (000048), BufAddr 0029C800-002A57FF, DBA 4029C800, BytesPerBlk 200
Blks 00152C-001573 (000048), BufAddr 002A5800-002AE7FF, DBA 402A5800, BytesPerBlk 200
Blks 001574-0015BB (000048), BufAddr 002AE800-002B77FF, DBA 402AE800, BytesPerBlk 200
Blks 0015BC-001603 (000048), BufAddr 002B7800-002C07FF, DBA 402B7800, BytesPerBlk 200
Blks 001604-00165D (00005A), BufAddr 002C0800-002CBBFF, DBA 402C0800, BytesPerBlk 200
Blks 00165E-0016B7 (00005A), BufAddr 002CBC00-002D6FFF, DBA 402CBC00, BytesPerBlk 200
so most looks good to me ..?
F on its own prints out loads of flags stuff from Byte:00A2: to 05C3:
And now ? is showing more/different info
Blks 001474-001487 (000014), BufAddr 0028E800-00290FFF, DBA 4028E800, BytesPerBlk 200 Symbol Error Map Log
Blks 0014E4-00152B (000048), BufAddr 0029C800-002A57FF, DBA 4029C800, BytesPerBlk 200 Drive Geometry Info
Blks 002AA5-002BF8 (000154), BufAddr 00554A00-006AE44F, DBA 40554A00, BytesPerBlk 1044 Default Diag Rd Buf
Blks 003579-0036CC (000154), BufAddr 006AF200-00808C4F, DBA 406AF200, BytesPerBlk 1044 Default Diag Wrt Buf
PostPosted: September 2nd, 2013, 15:54
ctrl-X gives lots of stuff, then hangs (a log of recent activity?)
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
9005 99999999 0 04 005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E27C Cnt 0006
9005 0 0 04 005041 000000 1 00000080 SRV_MEM Type 6 Addr 401E00A7 Cnt 0001
9005 0 1 04 005041 000000 1 00000080 SRV_MEM Type 8 Addr 0000E294 Cnt 0006
9016 11 5 12 005041 000000 1 00000080 TEMP 36 degC
9022 6 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD5D L 00000001 BO 000000 BES 003E033
.003E072.003E033
9026 4 11 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD86 L 00000001 BO 000000 BES 0045080
.00452FF.0045080
9047 21 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045080
.00450BF.0045080
9057 10 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045080
.00450BF.0045080
9078 21 9 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000000304E7 L 00000002 BO 000000 BES 0045100
.004517F.0045100
9087 9 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000304E7 L 00000002 BO 000000 BES 0045100
.004517F.0045100
9107 20 11 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045082
.00450C1.0045082
9118 11 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045082
.00450C1.0045082
9138 20 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045081
.00450C0.0045081
9148 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FDAC L 00000001 BO 000000 BES 0045081
.00450C0.0045081
9169 21 11 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002913D L 00000008 BO 000000 BES 0045080
.00452FF.0045080
9180 11 9 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000648B1 L 00000002 BO 000000 BES 0047FC0
.004803F.0047FC0
9189 9 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002913D L 00000008 BO 000000 BES 0045080
.004527F.0045080
9200 11 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006455C L 00000008 BO 000000 BES 0045080
.004527F.0045080
9221 21 7 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0045080
.004517F.0045080
9228 7 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0045180
.004527F.0045180
9238 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD41 L 00000004 BO 000000 BES 0045180
.004527F.0045180
61644 52406 29 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD5D L 00000001 BO 000000 BES 003E033
.003E072.003E033
61673 29 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD62 L 00000001 BO 000000 BES 003E073
.003E0B2.003E073
61683 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006B181 L 00000001 BO 000000 BES 003E073
.003E0B2.003E073
61693 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD63 L 00000001 BO 000000 BES 003E0B3
.003E0F2.003E0B3
61703 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006B182 L 00000001 BO 000000 BES 003E0B3
.003E0F2.003E0B3
1118613 1056910 23 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002BA07 L 00000180 BO 000000 BES 0032000
.0037FFF.0032000
1118637 24 11 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002BB87 L 00000100 BO 000000 BES 0038000
.003BFFF.0038000
1972645 854008 0 27 002241 000000 1 00000080 SND_SRV 516F 0000 0000 0000 0000 0000 0000 0000 0001 03AB 00D0
0000 0000 0002 4B4A 0020 30CC 46C3 6A49 1213 0000 0000 0000 00
00 0000 0000 0000
1972645 0 0 27 002241 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 016C 00D0
016C 0000 0002 4B4A 0020 30CC 46C3 6A49 1213 0000 0000 0000 00
00 0000 0000 0000
1972655 10 0 27 002241 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 016C 00D0
00 0000 0000 0000
1972664 9 0 27 002241 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 4E4D 00D0
4E4D 0000 0002 4B4A 0020 30CC 46C3 6A49 1213 0000 0000 0000 00
00 0000 0000 0000
but ctrl-z . seems to eventually get it back
PostPosted: September 4th, 2013, 6:43
Anyone any suggestions ?
The initial 1-2 minutes wait after power on before it responds to ^Z is strange
Does it suggest anything ?
PostPosted: September 4th, 2013, 7:34
Z and U spin down /up ok
with no LED error
PostPosted: September 4th, 2013, 7:35
Have you tried clearing SMART already?
PostPosted: September 4th, 2013, 10:26
F3 2>x
shows the zones ok
User Partition
LBAs 00000000-1D326C40
PBAs 00000000-1D5AB7E4
HdSkew 006E, CylSkew 0032
ZonesPerHd 11
Head 0, PhyCyls 000000-0441AA, LogCyls 000000-0435F2
shows info for zones 0-10 for heads 0-5
System Partition
LBAs 00000000-002C7173
PBAs 00000000-003527FF
HdSkew 006E, CylSkew 0018
ZonesPerHd 02
Head 0, PhyCyls 028243-028482, LogCyls 000000-000210
zones 0-1 for heads 0-5
Now to see / remember how to read a user LBA into the rd memory buffer (and locate the buffer)
but still don't really understand where to find user LBA's from the internal physical cylinders heads etc
PostPosted: September 4th, 2013, 11:44
No, not tries clearing SMART yet
with 1>N1 (if appropriate to an F3)
as don't want to risk anything yet
Is there a way to read SMART from the terminal ?
Also, regarding the delay between power on and ^Z being accepted -- I have a working 7200.12 that does that so might be normal
