Dear All
I know this case is quite common one here
And i've tried to find and browse around before i made this thread
So despite there are some similarities, somehow i see my case is bit different, or maybe i've missed the solution (if i do please point out the the solution's thread)
Anyway,
I have this 3Tb WD My Book, and the enclosure board is damaged (the light indicator is on but is not detected on the USB3 ports), so i purchased from Ebay for the replacement board (from this post in ebay _http://www.ebay.com/itm/200933646639?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 )
The hard disk is filled (and full) with my 5 years-collected data, and it was used for temporary back up before i distribute it to other hard disk before it failed.
My board's serial is 4060-705094-001 Rev. A (same with ebay seller's number/revision)
After i installed the new generic ebay-purchased board i only can see the hard disk (in WD SmartWare and Windows' Disk Management). With the old damaged board i can't. But i can't do anything about it since it's locked and read as raw.
Here's the view on WD Smartware (after the ebay's new board replacement):
It's locked (due to too many password failed attempt While i never put any password previouslyAnd here's the view of Windows' Disk Management (after the ebay's new board replacement):
(read as raw)
I just want to extract the data because i need it desperately
I can't go to recovery service (because it will cause too much, i'm a student)
I'm living in Indonesia with so many inconveniences (contacting WD office, finding sparepart/service guy to fix my old board)
I never do any soldering work and don't own microscope (it's too pricey here)
So any solution such as:
-a place to find other board which will fit exactly to my old one
or anything that'll help me to make this hard disk's content be possible to read
Thank you in advance
