Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10TMVW-11ZSMS5
PostPosted: October 1st, 2013, 8:47
More times than not, the heads are ruined when this happens.
When you remove the old heads, be sure to account for all of the sliders . . .
http://www.datasaversllc.com
PostPosted: October 4th, 2013, 2:30
neuron wrote:
ShaneWard wrote:
It's a bit risky, doing that could rip the head of the arm and then any chance is gone of recovery on your own...
And your method / procedure is??????
At least some professionals use head replacement tools to assist in the procedure.
As for overcoming the stiction force, I wonder if ultrasonic vibration of the platters might be able to achieve this without undue stress.
The following paper talks about such a method in relation to magnetic tape stiction:
http://www.micronano.ethz.ch/education/ ... _BB_03.pdf
Still another method might involve applying a "dither" voltage to the voice coil while turning the spindle. The following patent talks about an additional piezoelectric microactuator mounted on the actuator arm (which some drives now have), but I wonder if applying such a voltage to the voice coil would achieve the same end.
http://patentimages.storage.googleapis. ... 002549.pdf
PostPosted: October 4th, 2013, 9:26
On newer drives the HGAs might already be bent during the sticktion process, so even if you free them perfectly there is no guarantee they would be functional.
But obviously it all depends on a situation and that's where experience could help.
PostPosted: October 8th, 2013, 20:44
Thank you for all your comments.
This is very strange ... Heads stuck in the middle of the platters.
Since he told me the disk was without energy ...no power - USB.
Regards,
Ruy
PostPosted: October 9th, 2013, 5:17
I guess that if the heads were hot when the drive stopped spinning and did not properly mount the loading ramp, they could have fused to the disk surface. I am not sure if warming the platters and head up a little would give it enough movement or ability to unstick, but better wait for conformation from a professional before trying that. A direct force has a high chance of ripping the head off the arm.
PostPosted: November 3rd, 2013, 14:10
Thank you very much.
I appreciate all the info.
If a guru want to add more details.
Best Regards,
Ruy
