Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: TestDisk for Linux, recover after format...
PostPosted: November 14th, 2013, 21:01
mindfulness wrote:
This following is a good tutorial to making an image of your drive with free Linux software. You can run testdisk directly on the image. This gives you the advantage of trying stuff without worrying about making the issue worse.
http://www.technibble.com/forums/showthread.php?t=48269
Thank you very much! :D
PostPosted: November 14th, 2013, 22:03
If you wish to persist with DMDE, then you need to show us sector 64 of the physical drive, not of the logical volume.
When you launch DMDE, uncheck the Show Partitions box. This will place you at sector 0 of the physical drive.
Then select Editor -> Goto Offset -> select sector 64 (decimal). This will be the current NTFS boot sector.
Now go to sector 1953500000 and select Tools -> Search For Special Sector -> Boot Sector. This should find the original NTFS backup boot sector, if it still exists.
PostPosted: November 14th, 2013, 22:46
Sector 64 is all 00 00
Sector 1953500000 see photo:
PostPosted: November 15th, 2013, 3:21
Could we see a dump of sectors 0 to 2048?
Launch DMDE
Uncheck the Show Partitions box
Select your physical drive and OK
Select Tools -> Copy Sectors
Start Sector - 0
Number of sectors - 2049
Select File as the Destination
You will be offered a file name of lba_0_2049.bin
Save it and upload it
PostPosted: November 15th, 2013, 16:17
Here it is... :wink: :wink: :wink:
https://www.dropbox.com/s/7fo666gdo6jl3 ... 0_2049.zip
https://www.dropbox.com/s/j68gfyuxffoey ... 0_2049.bin
lba_0_2049.zip [5.08 KiB]
Downloaded 359 times
PostPosted: November 15th, 2013, 23:31
The TV has overwritten the beginning of your file system. :-(
I don't see any easy manual solution. I would clone your drive, or use data recovery software to recover your data to another drive.
PostPosted: November 16th, 2013, 1:35
Got it! :wink:
I will buy DMDE, and recover the whole partition to another external HD drive!
Thank you very much! :wink:
PostPosted: November 18th, 2013, 18:52
Recovered almost all file with DMDE! :D
Thank you very much to all people that helped me! :wink:
Users browsing this forum: No registered users and 236 guests
