 Post subject: Seagate ST2000M001 no prompt
PostPosted: November 24th, 2013, 17:04
Hi everyone,
Another Seagate died. Terminal input below. Does not let into prompt. Ideas on whether this could be fixed without specialist tools? Normal electronics stuff and programming is OK, but I have not worked on failed hard drives before.
Thanks in advance!
Boot 0x40M
Spin Up
TCC-0024[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0024
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0000280A
[RSRS] 07EC
ProcessRWError -Read- at LBA 0000000000066CE9 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000066CE9!
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-0024
LED:00000047 FAddr:FFFFFFFE
 Post subject: Re: Seagate ST2000M001 no prompt
PostPosted: November 25th, 2013, 7:04
Those reboots were made by you or by the drive itself?
PostPosted: November 25th, 2013, 7:46
That was the raw output after plugging in the drive.
PostPosted: November 25th, 2013, 7:53
And what about noises? Do you ear the regular noises or any strange noises?
Users browsing this forum: Majestic-12 [Bot] and 65 guests
