 Post subject: Samsung S4
PostPosted: December 10th, 2013, 8:02
Hi to all!!
I'm working in a case of smartphone Samsung S4.
This mobile does't have comunication by "mass storage", so I only have comunication usb by MTP.
I tried seek a good software how wondershare or others, but all software only work by mass storage.
Would you know some software that work by MTP?
Нет ничего невозможного
 Post subject: Re: Samsung S4
PostPosted: December 10th, 2013, 9:05
Whatever comes after S2 is MTP Protocol
such as: S3, S4, Note II and so on
in order to get some DELETED stuff ( if that was the original Question) then you will have 2 options:
1- ROOT it, evidence will be destroyed, (will Alter it)
2- Pro. Forensic tool, such as XRY & Cellbrite (which is really not cheap)
(personally tried option 2, where option 1 is not an option in Forensics)
so far ( as far as am aware of till today) no well known APP. to do that as certain.
good luck
PostPosted: December 11th, 2013, 15:20
good luck
Thanks reply!
PostPosted: December 11th, 2013, 16:49
Assuming the phone was in a sufficiently working condition, would it be possible to perform a raw backup of the internal memory and then use regular data recovery tools on the image?
Review of Android Partition Layout (FAT32, ext4):
http://www.all-things-android.com/conte ... ion-layout
Performing a Full Backup of an Android Device (using adb - Android Debug Bridge):
http://www.all-things-android.com/conte ... oid-device
Users browsing this forum: No registered users and 24 guests
