 Post subject: ATA password at boot
PostPosted: January 15th, 2014, 10:59
Hi guys, I had been following the ATA password thread and have managed to retrieve passwords that I already know ( through MHDD and hex workshop) but what is the process to retrieve an unknown one that prompts in the POST?
Would MHDD work if I were to boot from another boot device?
Let me know your setup pls as building a rig specifically for the job
Will have a couple of external SATA and IDE ports along with SATA and molex power
Will also have TTL Port access
Kind regards, Richard
 Post subject: Re: ATA password at boot
PostPosted: January 15th, 2014, 12:08
i'll have a look into pc3k and atola. thanks
I have received a quote for HD doctor but the pricing for that is a little too extreme for me in my current circumstances. I am just now trying to branch out into HDD recovery. I will be doing any methods that can be accomplished without the clean room and if a clean room is needed for the job then one is available (with experienced specialists) through an acquaintance :)
I appreciate that I am a noob to the forum and don't expect to be spoon fed but being pointed in the right direction is a great help :)
PostPosted: January 15th, 2014, 12:12
There are plenty of free tools.
Try ZU:
http://malthus.zapto.org/viewtopic.php?f=95&t=166
PostPosted: January 15th, 2014, 12:17
I have tried ZU with a couple, but continuous counter so I resorted to the HEX approach
PostPosted: January 15th, 2014, 12:20
I was trying with passwords I already know as a start, to ensure the theory works
PostPosted: January 16th, 2014, 17:56
Maybe it would be a good start if you at least told us what model/make you are talking about, and what you mean by "the HEX approach".
Users browsing this forum: Google [Bot] and 30 guests
