 Post subject: Loader for Atlantis WD6400AAKS-22A7B0
PostPosted: February 5th, 2014, 8:55
Hi
I also need this one...
Thank You
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 170
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.89D
ROM generation.......................... : 05.89D
Link table version...................... : 04.A6.
Consolidated ROM version................ : 00050089
ROM Modules:
Flash ROM dir reading................... : Ok
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00050089
ACELab partner
 Post subject: Re: Loader for Atlantis WD6400AAKS-22A7B0
PostPosted: February 5th, 2014, 9:03
heheh Again
the Beauty of 10 hands
11.rar [135.86 KiB]
Downloaded 536 times
PostPosted: February 5th, 2014, 9:12
Hi Einstein
This one is not compatible... Version 0005008A
I need the 00050089.
ACELab partner
PostPosted: February 5th, 2014, 9:20
pclab wrote:
Hi Einstein
Yes it is, COMPATIBLE my dear
it should work
u wanted for 640 and this is for 500 need proper entries only
good luck
PostPosted: February 5th, 2014, 9:45
Here you go:
WDC WD5000AAKS-22A7B0-01.03B01-WD-WMASY3154602.rar [136.5 KiB]
Downloaded 518 times
www.datasave.ro
PostPosted: February 5th, 2014, 10:58
einstein9 wrote:
pclab wrote:
Hi Einstein
it should work
good luck
Hi
Well, UDMA didn't liked it. It said "not compatible" ehehhe
Gonna try the one from ccc (Thank You ccc)
ACELab partner
