 Post subject: Loader for Atlantis WD6400AAKS-22A7B0
PostPosted: February 5th, 2014, 8:55
Hi
I also need this one...
Thank You
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 170
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.89D
ROM generation.......................... : 05.89D
Link table version...................... : 04.A6.
Consolidated ROM version................ : 00050089
ROM Modules:
Flash ROM dir reading................... : Ok
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00050089
ACELab partner
 Post subject: Re: Loader for Atlantis WD6400AAKS-22A7B0
PostPosted: February 5th, 2014, 9:03
heheh Again
the Beauty of 10 hands
11.rar [135.86 KiB]
Downloaded 555 times
PostPosted: February 5th, 2014, 9:12
Hi Einstein
This one is not compatible... Version 0005008A
I need the 00050089.
ACELab partner
PostPosted: February 5th, 2014, 9:20
pclab wrote:
Hi Einstein
Yes it is, COMPATIBLE my dear
it should work
u wanted for 640 and this is for 500 need proper entries only
good luck
PostPosted: February 5th, 2014, 9:45
Here you go:
WDC WD5000AAKS-22A7B0-01.03B01-WD-WMASY3154602.rar [136.5 KiB]
Downloaded 533 times
www.datasave.ro
PostPosted: February 5th, 2014, 10:58
einstein9 wrote:
pclab wrote:
Hi Einstein
it should work
good luck
Hi
Well, UDMA didn't liked it. It said "not compatible" ehehhe
Gonna try the one from ccc (Thank You ccc)
ACELab partner
Users browsing this forum: No registered users and 92 guests
