 Post subject: ST3000DM001 Wrong capacity or not recognized by BIOS problem
PostPosted: March 26th, 2014, 19:30
Hi there ... im new here at the forum .. but i know a lot about the hddguru's ... your softwares and knowledge has helped me a lot in the past ... im having trouble with a Seagate HDD ..(for a change) ...
the model is
Model:ST3000DM001
SN:Z1F1YRC6
PN: ICH166-301
PCB:100687658 REV C
3TB of capacity... The problem is that when the BIOS recognize the HDD and im trying to format with any partitioner i get the wrong capacity like 31 MB or 2 GB... and finally cant format.
Sometines it's not even recognized in BIOS.
I've tried to do a firmware update using Barracuda-GrenadaBP-CC29-CC49 but the firmware says there is no HDD compatible ... eventhough i see it at BIOS. later the firmware program put the model of the hdd as it was discovered but next it attach the word FAIL...
As im familiar with barracuda 7200.11 BSY problem i connect the hdd to a RS232 interface ... and I get this
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0003
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1C00 0053 03B4 3800 0008 0000 0000 0000 0F81 0000 0000 0000 0000
0000 0000 0000 D122 ED1F 764F 21C2 69A0 996C EF4B 46A7 F2EC 998F 0000 007F 0004
0000 001F 0004 0000
ResponseFrame 2680 0056 03B4 3840 0008 0000 0000 0000 0F75 0000 0000 0000 0000
0000 001E 0004 0000
this is display accompanied with a clicking sound. then nothing ... its not responsive to the ctrl+Z command in any state.
I've also tried the READ CHANNEL short-circuit .... at my own risk following viewtopic.php?f=1&t=25736 guidelines because its not the same PCB
Can anyone help me? excuse my english its not my mother tongue
thanx in advance
 Post subject: Re: ST3000DM001 Wrong capacity or not recognized by BIOS pro
PostPosted: March 27th, 2014, 2:25
is this new drive, or you already use it on this computer
PostPosted: March 27th, 2014, 7:31
does drive spin down after a while ?
Data Recovery Pakistan
PostPosted: March 27th, 2014, 8:43
no its not my drive ... its a friend of mine ... i've never used in this computer...and yes the drive spins down after writing the FAIL SERVO stuff into the terminal ... sorry took me so long to reply ... i only have internet connection at work ... thanks for answering
PostPosted: March 27th, 2014, 9:04
Then it has bad heads and/or media damage.
PostPosted: March 27th, 2014, 9:10
ok ... but the HDD its recoverable ... im not interested in the data ... just want to use the HDD .. even with less capacity ... im from Cuba ... getting a new HDD its difficult here
PostPosted: March 27th, 2014, 9:42
another thing i discover today ... sometimes when its writes to the terminal the FAIL SERVO stuff ... after that its enter a state that displays caracter that its an arrow pointing to the right... it does not leave this state even when i remove the sata power connector ... only when i remove the PCB from the HDD ... then enter the beep ... click click ... FAIL SERVO stuff displayed ... hope this help ... i repeat i want only to recover the unit ... even with less capacity ... not interested in data ... thanx for all yours reply
PostPosted: March 27th, 2014, 10:12
Use the search function here in the forum and look up keywords such as "ST3000DM001" or text strings from your terminal output. Take some time and enjoy the reading. You will have a better idea what you are against.
PostPosted: March 27th, 2014, 10:34
thanx labtech ... ive done that ... i saw the BSY post of a 7200.14 ... the motor stops post ... and several others .. including 2 tutorial ... the one with the Seagate Terminal Tutorial, and the one with the identifying the read channel points ... i think i've done some research ... but i decide to post here because im getting nowhere ... specially with the read channel short circuiting ... i think i located the points correctly following the tutorial directions about the Y shape of the PCB printings ... but the thing is that i dont know how to do it or when to do it ... and i think that this trick can do the magic base on a post from here ... what do you think?
PostPosted: March 27th, 2014, 12:06
The "terminal magic trick fix" works if the drive has a firmware failure. And the fix is more or less specific to certain module drives, not all.
In this case, for your drive, then drive likely has a mechanical failure (and possible media damage) as it has already been indicated by pcimage.
I suggested that you read the posts within the search function with the goal of looking for explanation content that would confirm for yourself that the failure is mechanical (and not firmware) related. Instead you are looking for all-in-one fix, which for this drive will not work.
I have no interest in misleading you as I have nothing to gain from this. Just wanted to help you understand for yourself.
Best wishes
PostPosted: March 27th, 2014, 12:47
sorry labtech if I show you a wrong impresion about what i understand from your reply... i dont think your misleading me, just that i didnt do enough on my on... im not a pro concerning HDD repairing so i didnt get that the drive was unrecoverable from what pcimage said ... as it's seem to be the case ... that why i told you that i,ve already done some things ... i not trying to discard anybody opinion here ... i trust this site and i know you are skilled ... just im not and im trying my best ... dont need a magic fix ... just to know what problem can be fix via a firmware update and when not ... thanks for your comment .. now i know that my friend has another Seagate paperweight
thanks for all
PostPosted: March 27th, 2014, 13:27
Firmware is installed on the disk itself. The mechanics have to be in working condition to work with the firmware. Since the drive's mechanics are likely failed, then the firmware can't be fixed.
The mechanics would have to be stabilized using another drive for parts and so on. In your case, it is not worth pursuing this as data is not important.
PostPosted: March 27th, 2014, 13:52
i agree with you ... i had have a LOT of trouble with Seagate products .. of almost all series ... 7200.11, 7200.9, 7200.14 ... 160, 250, 500GB ... in my country its very common to import Seagate products ... i have manage to recover some of them, by mean of the 7200.11 BSY solution or by simplest methods, like HDD regenarator, HDAT2, LLF, TEST DISK of Hirens BootCD ... others just become paperweight .... thanx a lot to you and the HDDGuru site
Users browsing this forum: No registered users and 124 guests
