 Post subject: ST500DM002 -KC45 Not Detect Please Help Me
PostPosted: April 6th, 2014, 4:02
I have a 500 and the hard drive can not be detected
Through this method, the terminal did
Please guide me please
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
ASCII Diag mode
F3 T>/2
F3 2>U
Spin Up Complete
Elapsed Time 0.000 msecs
F3 2>Z
Spin Down Complete
Elapsed Time 6.032 secs
F3 2>U
Spin Up Complete
Elapsed Time 3.703 secs
F3 2>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 1C, Max Certify Rewr
ite Retries = 0A8F
(DOS) Requesting File Save
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
ASCII Diag mode
F3 T>i4,1,22
F3 T>
 Post subject: Re: ST500DM002 -KC45 Not Detect Please Help Me
PostPosted: April 6th, 2014, 5:57
Were there any entries in Non resident Alt List before you ran m0,2,2,,,,,22?
If this is a direct screen dump, your have done some of this in the wrong order. Running m0,2,2,,,,,22 if there are still entries in Alt List is not the best way of doing this. By running i4,1,22 you have now cleared the Alt List too.
https://www.mjm.co.uk/
PostPosted: April 6th, 2014, 9:19
It's a more complete explanation did not notice
I gave the wrong command?
Or gave orders to move?
PostPosted: April 6th, 2014, 17:21
If you did the commands in the sequence above, then that has not helped the situation. can you get to T>
then type V40
put the result here
then do the same for V4
PostPosted: April 7th, 2014, 3:16
Hello
The commands you use are correct . but the procedure is wrong.
1. i4,1,22
2. m0,2,2,,,,,22
3. N1
but your hdd need only read channel short after complete calibration, until ready status. Because it was giving MCMT read request failed.
http://hddrepairing.com/forums/viewtopic.php?f=44&t=35
Waqas Ali
PostPosted: April 7th, 2014, 3:24
F3 T>V40
Nonresident GList 1 entries returned
Total entries available: 1
PBA Len Flags Phy Cyl Hd PhySctr SFI
245CB8D 1 20 ED72 1 109 75461
PostPosted: April 7th, 2014, 3:53
I think the translator is damaged now. The best thing to do in this instance is copy back translator and smart modules from backup and check V40 and V4 again and put results here.
PostPosted: April 7th, 2014, 4:21
Rst 0x10M
Spin Up
(P) SATA Reset
ASCII Diag mode
F3 T>V40
F3 T>V4
Reassigned Sectors List
Entries: 0000, Alts: 0000, Removed: 061C, Pending: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs S
tatus BBM Mask
F3 T>
PostPosted: April 7th, 2014, 15:35
hi
mc-recovery pls put ROM file this HDD for me
I have two Hdd of this model and firmware is crashed and I want ROM file for programing. by programmer. if 8pin on PCB
pls upload ROM file of backup if 8 pin on pcb
PostPosted: April 7th, 2014, 16:38
restore the translator and SMART modules from your sa backup. Then post the V logs
PostPosted: April 8th, 2014, 4:56
How restore the translator and SMART modules from your sa backup????
PostPosted: April 8th, 2014, 5:38
Yepp, thats the 100$Billon question, as I assume that with that question you don't have a SA-Backup.
Now things got from bad to worse, my only advice is to take it to a pro.
http://www.rescue-it.se
PostPosted: December 29th, 2015, 6:39
F3 1>N1
DiagError 00012001
F3 T>V40
Primary DST List 0 entries returned
Total entries available: 0
Nonresident GList 0 entries returned
F3 T>V4
Entries: 0000, Alts: 0000, Removed: 4012, Pending: 0000
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msec
s Status BBM Mask
Users browsing this forum: Google [Bot], jimmydata and 68 guests
