 Post subject: Coolermaster X-Dock Fried WD :(
PostPosted: April 11th, 2014, 8:50
Hello
I installed some new drives in my coolermaster pc case and now my old wd caviar sata had to get out the case.
So i would use the coolermaster x-dock bay to inserth the hdd and copy all the content.
So when i inserted the wd caviar inside the bay , the pc shutted down and after that the hdd stopped to spin.
I recconected it to a internal sata port but no luck. It sees to be fried.
After reading the forum it seems that the dock is faulty and a lot of hdd's are fried...So thank you coolermaster... :evil:
I ordered a spare pcb so to replace the fried one but it might need bios exhacge which need special tools.
The fried pcb has a burn in a small chip on the upper left corner...What is that?
do you think that with exchaning the bios chip the hdd will work again?
Does anyone have to propose a technician so to sent the pcb for repair?
I sent to all of europe :D
thanks for the help
Thodoris
 Post subject: Re: Coolermaster X-Dock Fried WD :(
PostPosted: April 11th, 2014, 16:56
Hello
Motor IC burned, maybe pre amp gone with him.
What is the pcb / HDD references ?
Good Luck
Récupération de Données
PostPosted: April 11th, 2014, 16:58
Can you measure the resistances of these components?
http://www.users.on.net/~fzabkar/HDD/bi ... diodes.jpg
If D3 and R67 are damaged, then your preamp would be suspect.
PostPosted: April 11th, 2014, 18:07
Θα ήθελα να συστήσω Northwind Data Recovery στη Θεσσαλονίκη.
http://www.datasaversllc.com
PostPosted: April 11th, 2014, 18:16
+1 Northwind
PostPosted: April 12th, 2014, 10:26
thanks for the replies
I used the donor pcb and the drive spinned up but after 2-3 seconds a tic tic sound came.
So i think that the preamp isnt shortcirquited.
Maybe a firmware trasnfer to the donor pcb make the trick?
Northwind price is about 400$ so want first to try my luck if there is a cheaper way :)
PostPosted: April 12th, 2014, 16:51
$400 is very cheap for preamp problem, snatch his hand off! :-)
PostPosted: April 12th, 2014, 17:08
If you wish to try this, then contact hdd-parts.com. They offer a PCB repair service.
See also viewtopic.php?t=28290&p=194567#p194567
You could also try to regenerate the ROM from the SA modules using WD Marvel Repair Tool:
http://wdmarvel.com/ru/
A 1 month licence costs $9.
Users browsing this forum: Google [Bot] and 154 guests
