 Post subject: Does Internet HDD Speed Effect USB Read/Write Speeds?
PostPosted: May 9th, 2014, 9:10
I have an old laptop that I use daily, it runs a 5400RPM 60GB HDD thats fairly new. When I run a set of benchmarks using different storage methods, I get very similar results.
1) Internal HDD gets average read 32.5 mbps / 15ms
2) USB 3.0 stick over USB 2.0 port gets average read 32.8 mbps / 0.9ms
3) External SSD in USB 3.0 caddy over USB 2.0 port gets an average read of 32.9 mbps / 0.5ms
My question here is, can the internal HDD be a bottleneck for read/writes via USB? (If not, is the CPU a bottleneck for read/writes via USB?)
Also, am I right to assume that using my USB 3.0 pen drive (as an OS) would be faster then using the internal hard drive, as it has a slightly faster average read and also a much quicker access time?
Thanks!
 Post subject: Re: Does Internet HDD Speed Effect USB Read/Write Speeds?
PostPosted: May 9th, 2014, 9:28
There is a feature called readyboost that is supposed to help system performance. I guess it basically uses a USB Flash disk as Ram, or swapspace... Though I have not looked at it at all, as it doesn't interest me a whole lot.
Most PCs, if you do a very simple test using the windows experience index, will show the hard disk as the component that brings the score down.
I would not recommend using a USB stick in this manner for reasons such as if any interruption to USB such as knocking it, or a USB port that is not very good at the connection will give file corruption, or can kill the usb stick.
IMHO, a better idea would be to ad a SSD, and increase RAM to full amount the MB supports.
Also, a 5400 with not much cache will give pretty average performance.
You don't say if you have made sure the chipset drivers, storage drivers and BIOS etc are all up to date, as this can have an effect.
PostPosted: May 9th, 2014, 10:19
I suppose you have a point about the USB stick moving out of place and causing a crash. I never thought of it like that.
My RAM is already maxed out @ 2GB so thats out of the question, also the HDD is PATA/IDE which means so SATA drive will work so I can't finder a faster drive for a reasonable price (unless I upgrade to SSD PATA which does exist.)
I'm actually running Linux Mint on the laptop so I'm pretty sure all the drivers are already installed. Also my BIOS is up to date.
PostPosted: May 9th, 2014, 15:44
I would use a tool such as HD Tune to display the read benchmark results graphically. This will tell us where the bottleneck exists. Otherwise I would copy data from each physical device to the NULL device rather than from the flash drive to the HDD or vice versa.
That said, 30MB/s is a typically maximum data transfer rate for USB 2.0 mass storage devices.
It would also help to know the model number of your HDD so that we could consult the manufacturer's documentation.
PostPosted: May 10th, 2014, 8:38
Hi, sorry for that. The drive is a: 60GB IDE Travelstar 7K100 HTS721060G9AT00
The odd thing about the USB is I used a USB 3.0 drive so naturally it should run much faster over a 2.0 port.
HD Tune does not exist for Linux but the inbuilt benchmark tool gives about the same results as when I was running Windows and using HD Tune.
Basically what I am wondering is, hypothetically speaking if I could replace my IDE with an SSD would the USB transfer rates speed up?
Thanks!
PostPosted: May 10th, 2014, 16:54
I don't think it works that way. USB 2.0 and 3.0 use different pins and signalling methods.
http://pinoutsguide.com/Slots/usb_3_0_c ... nout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
Here is a HD Tune benchmark result:
http://www.hdtune.com/results/Hitachi_H ... G9AT00.gif
The maximum transfer rate is 46MB/s and the average is 37MB/s.
If you use Linux dd to read LBA 0 to LBA 1 million, say, then that should result in the maximum possible transfer rate. Choose dev/null as the target device.
PostPosted: May 11th, 2014, 20:13
Thanks!
USB3.0 devices will not run past the maximum speed for USB 2.0 when placed into a USB2.0 port.
Also you are forgetting that most USB devices have a much slower Write rate than read rate, and using it as a HDD you need to do both.
Remember also that the USB reads to RAM then to the Hard Disk. So any read/write operation to/from the hard disk is not coming directly to/from the USB.
Users browsing this forum: Google [Bot] and 63 guests
