 Post subject: ST500DM002 Not Detect and No Terminal
PostPosted: June 23rd, 2014, 4:55
HDD INFO
Hello Everyone
No Click Sound and no strange sound but not detected in bios and windows.
Just spinng up and Head moves to the edge of the media and stay there , No Spin down.
In Terminal Just got
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
Then No Response
PCB Both Sides
Let me know the How to Short the read channel and when should short them.
Please guide with the procedure.
Thankyou
Parthipan
gpsparth@gmail.com
Madurai, Tamil Nadu, India
09944552088
 Post subject: Re: ST500DM002 Not Detect and No Terminal
PostPosted: June 23rd, 2014, 11:13
Use keywords to search here in the forum
PostPosted: June 23rd, 2014, 12:23
thanks for your reply
Searched the forum, resulting post mentioned to upload the pcb image (Topic in 2013)
I can't find answer for " At what stage i have to short the read channel ?"
Please guide me or point to the correct detailed topic
Thankyou
PostPosted: June 23rd, 2014, 12:31
Likely nobody would find an answer for such an expression: " At what stage i have to short the read channel ?"
And there is no exact answer as it varies. But in general, after the heads lock servo and before the reallocation begins in the background.
PostPosted: June 23rd, 2014, 18:27
did you open in a clean room? I am wondering how you know:
gps31 wrote:
Just spinning up and Head moves to the edge of the media and stay there , No Spin down
PostPosted: June 24th, 2014, 7:40
Which contacts did you short on the PCB?
PostPosted: June 24th, 2014, 8:58
Thanks for reply
1. MHDD did not see hdd.
2. PCB Change NO EFFECT.
3. Shot ( As per 5th Reply in http://forum.hddguru.com/viewtopic.php?f=13&t=28194 )
PostPosted: June 24th, 2014, 10:41
Did you click CTRL+Z after Sata reset is shown on the screen ?
HDD INFO
[code]Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
Then No Response
PostPosted: June 24th, 2014, 11:48
No response for Ctrl+Z
just hang with (P) SATA Reset
PostPosted: June 24th, 2014, 13:00
Read the forum more and be patient with the terminal
PostPosted: June 25th, 2014, 4:29
http://translate.google.co.in/translate?hl=en&sl=ru&u=http://forum.ru-board.com/topic.cgi%3Fforum%3D84%26topic%3D4756%26glp&prev=/search%3Fq%3DFAIL%2B%2BServo%2BOp%253D0155%2BResp%253D0007%2B%2BResponseFrame%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0000%2B0800%25600000%2B0000%2B0000%2B0000%2B000Ax%255B0x00025CB4%255D%255B0x00025CB4%255DZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZ%2BZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM%26client%3Dfirefox-a%26hs%3D3Zj%26rls%3Dorg.mozilla:en-US:official%26channel%3Dsb
When you turn the spindle spins without extraneous sounds system and the BIOS is not detect, it is necessary to close the read channel recording, reading and closes here that occur Spin Up [0x00000000] [0x0000B67C] [0x0000BA10]
is it correct ? but I could not lock terminal
Users browsing this forum: Google [Bot] and 67 guests
