 Post subject: ST ST2000DM001 Stops spining
PostPosted: June 24th, 2014, 13:17
Hi Gurus another time:
I have here another ST
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
Capacity : 3,86 GB (8 089 950)
when came to me the PCB was faulty, i schange PCB with NVRAM exchange too.
now
When i start it, the spin starts for about 3 secs, no clicking sound and spin down
TErminal Log:
_______________________
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0003
0100 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1EC0 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 4747 8C39 8AD6 6C2B 42B7 09BA FF97 0951 8D11 CB4C 0000 007F 000A 0000 FFF7 0004 0010
ResponseFrame 2700 0000 0000 7FC0 0008 0000 0000 0000 FBE7 0000 0000 0000 0000 0000 0000 0000 4747 8C39 8AD6 6C2B 42B7 09BA FF97 0951 8D11 CB4C 0000 007F 000A 0000 FFF7 0004 0000
any idea?
thanks.
 Post subject: Re: ST ST2000DM001 Stops spining
PostPosted: June 24th, 2014, 13:51
heads issue and possible media damage. ROM is native?
PostPosted: June 24th, 2014, 14:02
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
I see it's displaying wrong capacity ie not 2Tb
Loki
PostPosted: June 24th, 2014, 14:12
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
now
TErminal Log:
Boot 0x40M
Spin Up
any idea?
thanks.
Does it click 11 times then spin down?
PostPosted: June 24th, 2014, 14:32
hhddrec wrote:
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
now
Most likely preamp is dead as well.
Also can be a motor coil break - we have seen one such drive here.
PostPosted: June 24th, 2014, 16:53
Where was the fault on the original PCB? Was the 5V TVS diode shorted?
PostPosted: June 25th, 2014, 6:01
Thanks Labtech!
Yes ROM is native, because Serial : W1Exxxx is the same tath serial in HDD's sticker.
PostPosted: June 25th, 2014, 6:02
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
now
TErminal Log:
Boot 0x40M
Spin Up
any idea?
thanks.
Thanks Pcimage!
no, no clicking sounds
PostPosted: June 25th, 2014, 6:03
Dmitri wrote:
hhddrec wrote:
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
now
Thanks Dmitri.
I'll test motro coils and report here.
PostPosted: June 25th, 2014, 8:06
hhddrec wrote:
Thanks Labtech!
That's good.
Yeah, best is to start eliminating things one by one, starting with simplest.
Besides PCB, preamp may be a problem as well. Check for residue on the media from it should it have blown. Because cleaning after is not fun.
PostPosted: June 25th, 2014, 8:48
hhddrec wrote:
Dmitri wrote:
hhddrec wrote:
Model : ST2000DM001
Serial : W1Exxxx
Firmware : SC48
now
Thanks Dmitri.
Hi Dmitri
coils looks like tehere are ok.
i test it and measures are about 0,01 ohm
PostPosted: June 25th, 2014, 8:58
Thanks; visually not burned diodes or other ones. i'll do testing and report here.
PostPosted: June 25th, 2014, 11:25
I test de PCB. i think not Diodes in this case.
I think tehre are 4 fuses. i atach pic (not real pic. googled pic)
in case of fuses they are not shorted
measure is: 0.001 Ohm
PostPosted: June 25th, 2014, 16:10
The motor windings should measure around 1 ohm, maybe less. The zero ohm resistors should measure 0 ohms. You should be using the 200 ohms scale for your measurements.
PostPosted: June 26th, 2014, 3:34
Did you check whether preamp is good?
Motor coils is possible, but definitely more exotic diagnosis.
PostPosted: June 26th, 2014, 5:25
Hi Dmitri, thanks for your reply!
what you want to say:
PostPosted: June 26th, 2014, 5:29
Thanks fzabkar!
I used a very simpler scaler, maybe is not very accurate
PostPosted: June 26th, 2014, 5:34
OK, for some reason you notice the last sentence only :) Disregard the idea about motor coils.
Check the preamp.
PostPosted: June 26th, 2014, 5:55
Check the preamp.
Thaks Dmitri, I unterstand.
PostPosted: June 27th, 2014, 5:18
Hi guys.
i test inside HDA, no dust on platers and no dust on filter.
I replaced Heads with donnors ones, the drive cames DRY and i have acess to user area.
Now i am trying to clone HDD with DE, but the problem is thath every 10.000 secs read i get 8 secs imposible to read, and every 5 minutes the drive stops, i need manually start another time, and continue:
every 10.000 secs read i get 8 secs imposible to read.
then every 5 minutes the drive stops.
and i need manually start another time.
and so on
any idea?
